THE WOODRAT IS BACK!
where can I get an aluminum fence with 3/4" T-slot
Adrian Mariano
I got a new bandsaw (PM1500) and it's got this gigantic fence that is 7" tall or so, which is great when resawing. But I don't have a tablesaw and I do all my powered sawing at the bandsaw. And to get in closer than about 2" to the blade I have to raise the guard up. The low fence position works...except that because the fence is 7" wide in this position, it really limits throat depth on the saw. What I really want is a 2" or 1.5" tall fence for general use.
I thought I could just buy a second fence and cut it shorter, but they charge something like $300 for the aluminum extrusion. So I'm wondering if anybody knows of a more reasonably priced alternative source for something I could use as a fence. The T-slot is 3/4" wide with a 0.4" hole for the screw (which is actually closer to 0.3" wide---I didn't check the exact screw type).
Re: where can I get an aluminum fence with 3/4" T-slot
I know its not what you asked, but why not just attach a 2" wide piece to the side of the existing fence low enough to get in close? It could be wood or aluminum.
Grant Smith
Check out WoodHaven. They make very high quality jigs, fixtures, and accessories. Among them are the aluminum extrusions you may seek. I have found they accept a 1/4" bolt head nicely. I know it isn't what you asked for specifically, but its close, and you may be able to make it work.
At worst, you will likely find something else there you like.
Regards,
Grant in Iowa
Stuart Johnson
You might like the Carter Magfence II. With the t slots you can make any jigs or fences accessories you want.
https://www.amazon.com/CARTER-MAGFENCE-Universal-Magnetic-Fence/dp/B007ENWIQK/ref=sr_1_1?ie=UTF8&qid=1490790263&sr=8-1&keywords=carter+bandsaw+fence
Adrian Mariano
Do you mean take off the aluminum extrusion and replace it with wood? I couldn't figure out how to mill a suitable T-slot to do that. (Note that I'm mostly a hand tool woodworker, so if I buy expensive exotic router bits for this they'll never get used again. But it's not even clear to me that there's a good way to make this T-slot with the router. I'd need to use a ~3/4" wide slot cutter on a 1/4" shaft and make the cut with the cutter totally embedded.)
Or do you mean attach a small wooden fence to the tall aluminum fence somehow? Bolt it on? That decreases my throat depth compared to a solution where I ditch the tall extrusion, so I'd need a way to easily take it on and off, and bolts would be slow and cumbersome to take on and off.
Not clear enough
Keith Newton
You said, "The T-slot is 3/4" wide with a 0.4" hole for the screw (which is actually closer to 0.3" wide---I didn't check the exact screw type)."
I guess the top of the T is 3/4" wide, but what would you need the thickness of that to be? I may have some scrap would work, or could look next time I'm over at the metal recycle yard. I see lots of stuff there with T slots from the big glass shops that do store fronts and tall buildings.
If you are in a city with a big glass supplier, you ought to go by and ask if you can look around in their scrap bin.
Re: Not clear enough
Adrian Mariano
Why do glass shops have extrusions lying around?
The stock fence mounts onto a bar that is about something like 3/8" thick, so you loosen the screws and slide it onto that bar, and then tighten the screws. I'm pretty unsure about that 3/8" dimension. I'll take measurements tonight.
Re: Not clear enough - Pics?
Henry (Raleigh NC)
A couple of pics would certainly help me understand exactly what you are hoping to do (I think I understand, but am not certain).
I know it is not the easiest thing in the world to load pics here on WC, but as I understand it you primarily need to adhere to the file size limitations. Although I can't tell you exactly where that info is he on WC, it is here (see FAQs or archives perhaps?).
Henry
Adrian, I just went to YouTube and looked at a video review of your bandsaw and fence. The fence can be used in an upright or horizontal position. With it laid down it would severely reduce the width of the rip because of the limited throat depth. but it would work for a lot of stuff.
Back to my original Idea. You can buy aluminum Tee slot extrusions to install in your own projects, jigs or fixtures. You could get a piece of that and attach it to a piece of hardwood and make your own low fence as I suggested above. If you have access to a table saw or a router you could recess it into a slot, or you could just surface mount it.
Or, you could build an auxiliary fence out of had wood by laminating strips onto a piece of wood In such a way as to create your own Tee slot Or include a bought one.
Another thought. Why not just remove the aluminum fence you have and the bolts and use the face of the existing fence? You can buy sticky back Teflon tape to slick it up if you wish.
Adrian Mariano
Making a wooden fence by laminating is a possibility that had not occurred to me. I could even use a sheet of aluminum for the back layer so it would be the same thickness as the stock fence, and hence easier to swap fences. Thanks for that idea.
In order to make a fence by mounting T-slot to wood I would have to buy T-slot somewhere that fits onto my fence mounting bar, which is why I'm looking for something with 3/4" T-slot. I have not seen anything (other that the $300 official replacement part) with a T-slot this size. Woodhaven said they can't help me. T-slots are usually 1/4" or 5/16".
I think using the fence without the aluminum part would still force me to raise the guard up higher than I want because of the big guide wheels. I'll have to double check. I also don't know if it's flat---could that be an issue? Are fences usually aluminum so you don't kill the blade if you cut into the fence by accident?
Try 80/20 extrusions
John in NM
They often sell short pieces on ebay. I can't quite make out what you need, but if you look at 80/20's website you'll be able to figure out if any of their patterns will work for you.
If the bolts in the fence you have now won't fit in an ordinary Tee slot Remove them with the aluminum fence you have now and change them to bolts that will fit your new fence.
Adrian Mariano
I have a picture ready, and it meets the 80 KB limit, but the FAQ says to "browse to your photo" and I can't figure out how to do that. Is the FAQ wrong? Do I have to put my picture on an internet hosting site and link it?
You just need a profile...
John in NM
You can post without one, but if you use a profile there will be an "upload" picture button or something like that below the subject box.
Adrian
Finally, the picture. The mounting bar, which runs almost the whole length of the fence, is 3/4" tall and it is 3/4" above the table. The thickness of the bar is 0.362". The mounting bolts are M8 (or 0.315" diameter).
Re: Try 80/20 extrusions
Adrian
That 80/20 system looks interesting. I hunted through the different sizes and from what I can tell, they have a few where the T-slot is wide enough, but it's not deep enough. (Need 3/4" wide and 0.37" deep with a 0.315" (8mm) opening). The basic profile they use has a diagonal brace running through the center of the extrusion so that makes the T-slot shallow.
Re: picture
Stuart Johnson
From the photo it looks like you can slide the fence off the bar, lay it down flat and slide it back on leaving you with a low fence. I think someone mentioned that is shown in the manual.
Re: picture
Adrian
Yes, and you lose about 7" of rip capacity, so then there's the need to keep flipping the fence up and down. I suppose you could argue that it's not that big of a deal to flip it, but I find it annoying and would rather have one position that works most of the time, which was the case for my old saw with a much smaller fence. I'm looking for a fence is more like 1.5 x 2 in cross section or something like that. Initially I was thinking of just getting a second fence and cutting off all the top sections. But $300 for the single extrusion?!? The 80/20 extrusions someone else mentioned are 50 cents an inch.
Fence on other side?
Henry (Raleigh NC)
I don't know if this helps, but.... Can you not position fence on the RIGHT side of the BS blade?
I know I can with the simple fence installed on my Jet 14" saw. That way you still have plenty of rip capacity (on a 14" BS, I forget if you stated what make/model your BS was). That's not unlimited capacity, but likely enough to deal with most wide stock I deal with, except plywood. Doing so requires slight adjustments to stance and stock feeding, but it's not a difficult adjustment really.
Henry
Re: Fence on other side?
Adrian
I don't understand the advantage of putting the fence on the right. If I have a board with one flat edge that edge needs to go against the fence, whichever side it's on. If I put the fence on the right in low position then the flat edge goes against the fence to the right of the blade and I will have less rip capacity than I would with the fence on the left. (That is, if you consider the total range of fence movement, the blade is more towards the right side in this range.)
The only time I've ever put the fence on the right was when I had the table tilted because then gravity was working with me instead of against me on keeping the workpiece against the fence.
Re: Fence on other side? OK
Henry (Raleigh NC)
OK - I think I get it.
Just thought I'd mention the idea in case it worked.
Henry
John in NM
Yes, you would have to replace the part that engages you extrusion with their T-nuts and probably bolts as well. But that would be pretty trivial to do if it solved your problem.
Alternatively, you could modify the equivalent nut-part that is too large on your fence. Just grind off the corners and it would likely fit in the 80/20 track and also still work with the factory fence extrusion.
Adrian
Maybe I'm working too hard to keep easy compatibility with my existing fence.
Right now I'm favoring Barry's solution of building up a fence using wood. I would epoxy and/or screw on aluminum strips to cap off the T-slot so that it's very easy to swap between the stock extrusion and my shop-made attachment.
Anybody know if I can countersink screws into 1/16" thick aluminum?
Countersinks
John in NM
A regular countersink bit will cut aluminum, but screw heads are usually taller than 1/16" unless they are very small screws. Depending on what it underneath you could perhaps make it work still, it would depend on a couple aspects of the design as a whole. If it were just 1/8" thick, you could probably get away with relieving the underside of the screw heads, though even with just a couple that is a pain to do by hand.
I've seen thin metals countersunk by pressing in a depression instead of cutting one. The material on the other side must be relieved (or absent) to accommodate the shape of the pressed countersink. The idea is to give the screw head maximum bearing area on the thin metal while still leaving the head flush with one side. It's a technique I associate with cheap manufacturing though.
Re: Countersinks
Adrian
I found that mcmaster gives the head thickness, and it looks like #2 screw are the largest size that would work, at least in the normal flathead pattern. I was thinking that using screws would help keep the aluminum properly aligned. I suppose I could use bigger screws and then cut them off after the epoxy cures.
