200+ woodworking book reviews
centering screws in a hinge hole
I'm installing hinges on the door of the display cabinet. I struggle getting the screw pilot holes perfectly centered. What techniques do you all use?
Re: centering screws in a hinge hole
centering punches......
I have done a number of things with varying success. I have a spring loaded center punch with a counter sunk tip. Put it in the hole and give it a tap. I think the pin needs to be very sharp and it's not. Has a sort of blunt rounded tip and tends to deflect off hard grain. I have also used a counter sink in a drill. Put it in the hole in the hinge bad touch the trigger. Try not to over do it and wallow out the holes in the hinges. I have used a sacrificial hinge for this. And maybe the best is the Vix Bits. A bit inside a spring loaded counter sink shaped sleeve. They work well. There is a little learning curve to keep the spring loaded part working and clear of chips. These seem to less sensitive to sliding off the hard grain into the softer wood.
Ron Pemberton
I have a set of these screw centering bits I use.
they work great
Joseph Piotrowski
i can't get a pilot centered in a hinge if my life depended on it. these things are awesome and work perfectly. doing 20 holes on a piano hinge is no problem at all
Re: VIX Bits
William Duffield
There are other manufacturers of self centering hinge bits that work as well as the VIX bits. These includes Snappy.
For large work (e.g., exterior door hinges), the Starrett center punch recommended by Chris Schwarz works very well,
http://www.popularwoodworking.com/woodworking-blogs/chris-schwarz-blog/anarchists-2015-gift-guide-day-2-starrett-819-centering-punch
but for small box hinges, it is much too brutal, and has trouble actually finding the center of the countersink.
Re: VIX Bits
jcousins
+1 for vix bits
jerry
Re: they work great
Bruce, a MN Galoot
Where did you get them?
Jack Guzman from Maine
I use these *LINK*
I used all kids of self centering bits but since I got these from Rockler it is all I use for cabinet hinges.
Jack
insty-bits
Gary Smyth
I have several sets collected over time. I have several types of spring loaded punches, true vix bits; and vix style and transfer punches. I don't care for the spring loaded as with the pressure I can't control them well. The vix work fine but I find that when in the drill there isn't always room I can't make them perpendicular to the work and they insert crookedly. I like the transfer punches as they fit to dimple the correct size hole which is all that is needed in most applications. Once dimpled you can drill afterwards if using brass screws. They are about 8" long and hand pressure is all that is needed for the dimple. Usually these come in 28 and 33 sizes sets. The best set I've found for very small screws is the transfer punch wire gauge set 1-60.
Vix:
Transfer:
Wire gauge:
I'm surprised a hand-tool guys knew about vix
Keith Newton
Do they make a set that fits a yankee drill? I'm just kidding of course. I've got a couple of them stashed somewhere just in case electricity becomes a thing of the past. ha
Re: I'm surprised a hand-tool guys knew about vix
William Duffield
Nah, no square tapered tang version, but they fit one of these just great:
My Millers Falls #97 has a higher gizmosity factor than my Festool T12+3. A disisadvantage is it weighs a lot more so I have to be careful not to break bits for the smaller screws :( .
Just because I like hand tools doesn't mean I like my power tools any less. My shop has a 100 Amp service panel.
Re: I use these
Bruce, a MN Galoot
Thanks, Jack.
A tapered Fuller bit....
John in NM
I've never cared for Vix bits myself. They are quick, to be sure, but they do not perfectly center. Best route if that is what you want is a pointy bit (they are easier to correct if you are a bit off) and a bunch of practice. It's like the sawing to a line on the bandsaw you mentioned not long ago - seems hard until you are used to it. same with centering by eye.
Philips screwdrivers.
TomD
I place the hinge in it's socket. I take an awl and lay it in the hole at an angle so it is supported by the hinge. I place the point where it needs to go, and I rock the handle into a vertical position. When done properly the hole is dead center. You can give the awl some English if it is off center, so the hole becomes centered. Also, you can use the drill at an angle for the very first bit of drilling to steer it to center.
Most important thing in getting a 100 year screw hole is the proper pilot. I don't see the kind of drill I would want to use in those production tools.
General hand reamer/countersink
Grant Smith
While not ideal for tiny jewelry box sized hinges, the General model # 196 hand reamer works good for this application. I also use it to make minor adjustments to the factory countersink on hinges and such. It is aalso a nice deburring tool for drilled holes.
It is "Generally" a nice thing to have around. Six to twelve bucks depending on where you buy. I got mine years ago at Sears (Can't believe I can recall where I got most of my tools).
I also use VIX bits, but as others have said, there is a bit of wander in the center bit in relation to the sleeve. They work, but not a flawless solution.
Joe Mohnike
I have the Vix, the center punches the hand reamers/counter sinks, etc.. But I have found the Phillips bit works just fine. I set the hinge in place, bore through a screw hole with the Phillips bit eye ball it and adjust accordingly which is not required too often. then I drill a start hole if required. Just my 2 cents worth.
Dave Bair
I eyeball it, using the business end of a throwing dart that lost it's plastic feather. The hardened point is very sharp and can be pressed pretty deeply into the wood by hand pressure, followed by a tap with a light hammer, if necessary.
question
I have been forcing myself to do the pointy thing instead of the tried and true Vix-Bit (which in itself needs some practice and good technique to be tried, and especially true).
How do you keep the pointy thing from going astray in wood like ash where there are hard/soft boundaries conspiring to move the pointy thing off-center? (I got 8 of 9 ok and one amiss. And when the error is on the barrel side it pulls the hinge out of the mortise.
resharpened awl
Clifton C
Bill, I have sharpened one of my awls to a three sided pyramid point. Opposite each flat is a sharp edge. In use, I lightly start the hole to see which way it wants to drift, then place a flat to that side, which places a sharp edge in the direction I want to drift the hole. A little wiggle (twist) and a check to see if I'm drifting in the right direction, if I am, I keep going, if not I place a flat to the side I don't want the awl to drift to, or, place an edge to the side I want to drift to. A few degree twist twist is all that is needed to check the drift... Not sure I've explained this vary well at all, however, if you sharpen an awl to a three sided pyramid you will see that it can be steered away from one of the flat sides.
cc
Re: resharpened awl
Don Stephan
Very interesting idea! Thanks for sharing.
Re: resharpened awl
John Pappas
Clifton, based on info in Paul Seller's book, I filed an awl in a square profile. Works much better in creating pilot holes, and I imagine your technique, which makes a lot of sense, would work with a square profile as well. I'll have to try it out.
Centering screws is one of those hand skills we develop, along with judging and sawing square with a hand saw.
I have a centering punch and the centering drill bits, and they all work well. I use them, too, as they are quick and accurate. However, they are not always available, or not the correct size, and then one must be able to do it by eye.
I usually begin with a tiny dot using a scratch awl. More often I jump over this and go directly to my birdcage awl ...
Link: http://www.inthewoodshop.com/ShopMadeTools/BirdcageAwl.html
