has anyone bought brass screws lately
I went to install some hinges today and found the brass screws I bought a few years ago are of poor quality. I think I got them from LeeValley, but not sure. They were in a plastic bag and I think made in CA. The arias is blunt and the threads crude. So, I need to get some different #7 x 3/4" screws. Why #7? The hinge has a screwy sized hole. A #8 sits proud of leaf and a #6 is buried.
Screws I got from White Chapel a few years ago are of good quality but I don't know if they still sell the same quality screws.
Re: has anyone bought brass screws lately
Paul in NJ
Bill,
If you don't mind the copper color, silicon brass or bronze screws are much better quality and a lot stronger. I buy them from Jamestown Distributors online. Have been a satisfied customer for many years.
Paul Dzioba
John McGaw
Not lately. I bought a ridiculously huge number of solid brass slotted screws from McFeely's some years back and found them to be of excellent quality. I probably have several lifetime's worth of them at the rate they get used around here.
re-cut the countersink to fit a #8 ?
ian
have you thought about re-drilling the countersink to take a #8 screw, see this example from Lee Valley http://www.leevalley.com/us/Wood/page.aspx?p=44708&cat=1,180,42240,42281&ap=1
Bolt Depot......
roger lance
A check of Bolt Depot's web site finds that they offer a full range of brass wood screws including #7s.
I have been purchasing products from them for awhile and am very happy with them.....no problem recommending them at all.
Countersink and use #8's?
Brian Holcombe
Bill, can you just countersink the hole more? I use a countersink for wood and it works on brass hinges without issue, cuts cleanly and does not wear the bit to a noticeable degree.
I use brass screws mostly from McMaster Carr, not sure the source but they are good quality and install well.
trading one problem for another
I still need to buy screws if I remill to #8, which I would rather not do. The #8's I bought (from Lee Valley?) are too poorly made to use. The screws even at #7 look out of place large in the hinge. I'll try McMaster Carr screws. thanks.
Horton Brasses *LINK*
David Yoho
Bill, the best brass wood screws I ever found were from Horton Brasses. Because of the restoration work I did on antiques as well as building reproductions I needed quality flat head slotted screws. I ordered an assortment of sizes and lengths that served me well. Their quality is top notch.
Horton Brasses
Re: re-cut the countersink to fit a #8 ?
Larry
When I use brass screws, I always use steel screws first, remove it and replace it whit a brass screw.
Robert LaPlaca
Jamestown Distributors has quantity brass wood screws, http://www.jamestowndistributors.com
I've not...
John in NM
So I'm glad to hear some of this info, maybe prevent getting some lousy ones.
Last time I bought brass screws, it was at Woodcraft, maybe 15 years ago (been building houses and gunstocks more than furniture since then). Those were good screws. The Woodcraft in Albuquerque closed around 2008 or so, I've rarely been in one since.
Gotta watch McMaster...
John in NM
We buy a lot of stuff from them at work. 99% is great, but we've had problems twice with getting either a non-premium brand or being mislead on the specifications of the product (and in that case I have no doubt it was the manufacturer rather than the vendor at fault). But the lesson in both cases was that McMaster gives you no information on who the manufacturer is, so you can't do comparison research.
Personally, I would source brass screws from Horton or Whitechapel instead, because they both have a vested interest in providing the quality you want.
