Depth Stop Problem with PC 690 Plunge Base
Lee Ohmart
I have noticed a problem with my plunge base that came with the Porter Cable 690 Combo set. The depth stop keeps loosening up so when I plunge the bit ends up boring a hole. This just happened on a newel post I had hours into. The knob to tighten the depth stop is not very big so to really tighten it down takes a really strong grip. Anybody else have this problem and were you able to solve the problem with this base or just switch to a different manufacturer?
Re: Depth Stop Problem with PC 690 Plunge Base
Lee Ohmart
Oops. the PC combo is the 890 not 690.
roger lance
Lee....I have a 690 style plunge router and have not had your slippage problem (yet). I was having a similar problem with a hand plane deep stop which I was able to fix by applying a small piece of 100 grit self sticking sand paper against the shaft of the deep stop....the increased friction solved the problem.
roger lance
Lee.....I just checked my PC plunge base.....there's not enough room for my sand paper idea to work.....sometimes, you can rough-up the shaft itself to create more friction or replace that tightening screw with something that you could tork down harder.
roger lance
another idea would be to replace the metal depth stop bar with a wood dowel.....the hand tightened screw might be able to get a better grip on the dowel which could also be sized to allow some sand paper as well.
George Koch
That's what I did with mine. Replaced the thumb screw with a larger knob. That did the job. George
Lee Ohmart
Yup. The larger knob seems like the way to go. A look around at PC plunge bases made after mine all sport knobs with wings on them allowing a greater amount of force to be applied to the shaft. That is also along the lines of the advice I got from the PC customer service department.
I have to say that once again my experience with PC was underwhelming. First they tried to say the problem was uncommon. (You're a whiner) Then he suggested my screw had a high spot and filing the end would help. (Fix it yourself) He next suggested replacing the knob with one that allowed me to apply greater force. No offer was made to supply one for my trouble or even an attempt to sell me one. (Yeah, it's a defective design, so sue us) Failing that he suggested using a bolt and applying torque with a wrench. I told him I was disappointed with his advice and future tools would be a different brand. He did not seem to care.
Lee Ohmart
I got a larger knob today and what a difference. After I reefed down on that knob and tightened the guide rod, I could put almost all my weight on that base and it didn't move a bit.
