A55 Smoothing Plane
Gun cabinet
Gun cabinet
Gun cabinet
Bruce, a MN Galoot
A couple years ago a friend asked me if it was true that I built furniture. Yes, I said. Well, she said, her husband had a stack of cherry that they had cut down in their woods and it had been drying for a few years, so would I make them a dining table with it. I did, and they must be happy with it because last summer her husband asked me to build him a gun cabinet. He brought me a picture and said to make something like it. His only specific request was that the door panels and back panel were to be made from cedar.
Well, first of all, all the best wood went into the dining table, so what was left was pretty much culls. But I said I'd try. This is the result:
More than half of the labor in this cabinet was devoted to making wood, making some usable lumber from what was left of the original stack. It was twisted, cupped, and cracked. It was also absolutely full of worm holes just below the bark. There is a lot of tinted epoxy filling a lot of worm tracks, cracks and knots.
The upper case is half-blind dovetailed. The bottom case is half-blind dovetailed plus a sliding dovetail for the bottom shelf. All the milling is done by machine, dovetail joints cut with a combination of router and chisel. All the fitting of joints and finishing is done by hand. The crown molding was cut on the TS (p.s, I found that a rip blade makes a much better cut when cove cutting than a combination blade).
There is no finish on it, so the color doesn't show properly.
They are really good people and wonderful customers. They had no deadline on this project at all. Actually, they were surprised that I delivered it on Monday. It was a great project in one sense, that I could work on it when the spirit moved me. That was really nice.
Re: Gun cabinet
Re: Gun cabinet
Joe shelton
Looks good. I don't think the cedar needs a finish. Did it come from his property, good!
Re: Gun cabinet
Re: Gun cabinet
Bruce, a MN Galoot
Thanks. yes, both the cedar and cherry came from his property. Cedar is common in MN, but I never knew that cherry was native, too.
Re: Gun cabinet
Re: Gun cabinet
Chuck Bjorgen
Very nice, Bruce. Did you mean no finish when the photos were taken or was it delivered with no finish?
Re: Gun cabinet
Re: Gun cabinet
Bobinnp
I built almost the same cabinet a couple years ago for a young mans dad in exchange for an engine rebuild on my old truck. He wanted to to put the finish and hardware on himself so that he would be able to say he contributed to the project. Tragically, he passed away during shoulder surgery. The gun cabinet was too hard for the dad to look at and given back to me as I delivered it,no finish, no door lock hardware. It sits in my shop to this day awaiting finishing. I wanted a solid door lock system with one central lock with bars that secure top and bottom of the doors. Haven't come up with a plan as of yet. I was wondering what type of lock system you used on this cabinet?
Re: Gun cabinet
Re: Gun cabinet
John in NM
It looks fantastic Bruce, great work!
Funny how working with rough lumber can either be so easy or so difficult - easy to get nice thick pieces when the lumber is good, and a time consuming struggle when it's not. I still prefer it though, even when the lumber is difficult.
Also interesting what you say about the blade for cutting coves on the TS. I'd forgotten that, but as soon as you mentioned it I remembered finding the same. Rip blades are usually cut square on every tooth, so you don't end up with slightly deeper lines from the pointy teeth on a combo blade.
Re: Gun cabinet
Re: Gun cabinet
Bruce, a MN Galoot
Thanks, Chuck.
No finish on it when delivered. They will varnish it sometime this spring.
Re: Gun cabinet
Re: Gun cabinet
Bruce, a MN Galoot
I just got keyed-alike locks for top and bottom of the door. I have figured out a system like you describe. The owner has young kids and just wants to keep them out curious hands, kind of an out of sight, out of mind approach.
Re: Gun cabinet
Re: Gun cabinet
Bruce, a MN Galoot
Thanks, John,
I found out about the blade the hard way. I cut enough of the cove for one set and the cut the wrong angle on the last piece. So, full of self-loathing, I had to make a matching piece. Fortunately, I had marked the table saw top with black magic marker and the angle marks were still there. All I had to do was match depth of cut. That's when I discovered the difference between rip and crosscut blades.
Re: Gun cabinet
Minnesota Cherry
The farther north it grows the prettier it gets, up to the point where the trees get stunted. The nicest grain and color cherry I ever bought came from near Minneapolis.
Re: Gun cabinet
Re: Minnesota Cherry
Bruce, a MN Galoot
some of it was pretty nice, especially the wood used in the table. This had some good grain but at the expense of cupping and twisting. Some of that is due to the fact that the wood was cut and dead packed. It was never kiln dried nor really properly air dried.
Re: Gun cabinet
Agree, and...
Grant Smith
I have found that Cherry trees that grow on the north side of slopes and on the south side of a clearing often have the best chances of being figured. At least here in Eastern Iowa, it seems the trees have much more character than what I have seen commercially available.
Of course the commercial stuff is often select and better grade, with the lesser stuff going to the pallet mill. Bill, maybe you could speak to what makes it to commercial woodworking market and what is used in other ways.
When I began woodworking, I would pick through piles of lumber and choose the straightest grain lumber for my projects. Certainly there is a time when that is appropriate, but these days I prefer to celebrate the natural "imperfections" in a project rather than trying to use perfect wood. One must balance this, however with ensuring a given piece fits the character of its purpose and place. I wouldn't make a rustic sapwood filled cherry piece for a room with Queen Anne furniture, for example.
It appears there is now a market for projects with sapwood, inclusions, and live edges. Indeed, I dare say some of these pieces bring more than their contemporary fine woodworking counterparts.
Regards,
Grant in Iowa
Re: Gun cabinet
Re: Agree, and...
Bruce, a MN Galoot
For flat panels, carcase sides, etc., I look for figure, too. But when I was trying to find enough straight, flat wood for the door frames, let me tell you it was a trial.
Re: Gun cabinet
what gets sold....
Everything #2 common and better is sold into the wholesale lumber market. The "worser" stuff goes, typically log hearts, into pallets. Most furniture is built from cuttings from #2 and #1 common lumber. For people that know how to cut efficiently #1 common is the best value in hardwood unless you need long clear cuttings.
I watched a mill that specialized in cherry saw one day. Their logs were smaller and shorter than what I was accustomed to seeing sawed. The logs were turned as they were sawed to expose news faces of hoped for clearer lumber. Normally a mill will keep sawing on a log so long as there is some face that is #2 common of better. However, at this mill as soon as they reached a 4 x 5 "cant" (I am recalling this size and it may be slightly inaccurate) they rolled the remainder off the carriage and started a new log. It was not uncommon to see these cants with clear faces remaining. I was told the cants went off to a resaw for pallets. The mill played the odds that sawing off one more board would not produce a marketable board (grading from worst face) and the remaining cant would be worthless to their pallet market because it was too small.
Re: Gun cabinet
Re: Agree, and...
TomD
I prefer quarter sawn wood in door frames, straight with low runout. It is surprising how little wood that I cut myself will yield that. One will often have one flaw somewhere but that is too much for quality work.
As to the style of things most clients aren't sophisticated and don't have much training in these matters. So boiling grain is attractive, if for no other reason than that even the cheap furniture mills did not generally make their stuff to look like that. Straight wood is rarer than the wild stuff so I do prefer it when i can get it. Bookmatching can create lovely effects without having to compromise the integrity of the wood.
Re: Gun cabinet
ebd
Re: Gun cabinet
ebd
If that was made from culls I'd love to see the table. Gosh that's pretty.
Re: Gun cabinet
Re: Gun cabinet
Bruce, a MN Galoot
Thanks much for the kind words. Here's the table. Bear in mind we didn't have a good place a better pic.
In this pic, the maple underneath the top is to support an extension on both ends.
