Delta DJ 15 jointer
Delta DJ 15 jointer
Delta DJ 15 jointer
eliot feldman
I'm having a terrible time finding finding parts for this machine. Getting through to Delta is a nightmare, and other parts dealers want the model number. I only see a serial number and a cat. no. on the machine. All I need are 6 inch knives and one of those little knife adjustment risers. Can anyone help me out?
Re: Delta DJ 15 jointer
I have some 6" knives I can let you have. Maybe more than one set. I am changing the head in mine to a Byrd/Shelix head. Send me an E-Mail if interested. Boy have I got s deal for you.
I do not have a setting jig. I set mine by just dropping them into the head until they get to be too narrow. Then I slip a shim under each one. This assumes you can adjust the outfeed table to match the height of the knives.
Does your head have the jack screws under the knives? They make it easy to adjust the knives.
eliot feldman
I would be delighted take a set off your hands! THAT is a deal! How do we go about it? I hate to ask you to go through the trouble of mailing them to me. Should I send you a self-addressed box, or something like that?
As for adjusting, on my jointer there are six little do-hickeys that fit under the knives -- two per blade. There's a tiny set screw in each one that moves the knife up or down when the screw is turned. I wouldn't call it a jig; it's just a way to set the height of each knife.
knives are easy to get
Any place that sells cutting tools to the wood industry can make your knives at what likely will be lower cost. They buy knife stock by the mile and custom cut it to specification. For example, Misenheimer, Morristown TN
roger lance
a.) 37 - 155 set of three knives
b.) 1246158 m5 x 16mm soc set screw
c.) 1330112 knife lifter
hope this helps
Let me rummage around a bit, I know I have one set because I just took them out of the machine. I think I have a couple more sets. Let me see if I can find them. I will send them to you in return for a donation of your choice to Wood Central. Send me your address. You can e-mail it if you don't want to post it.
William Duffield
I have a DJ20. It works the same way as the DJ15, but it's a couple inches wider. I set it using the jack screws and a 4" double square. My method doesn't require me to reset the outfeed table every time I replace the blades. I set the square on the outfeed table and adjust each end of each knife until it just rubs the edge of the rule as I rotated it through top dead center. If the shop is quiet and well lit, I can hear the blade scrape against the square when it's high enough, and I can see the blade lift the square when it's too high. Only problem is that the height of the jacks might move when you tighten the locking screws, especially if any of the moving parts have a bit of grit or rust in them. Make sure all the parts of the head are as clean as possible before you start the adjustment. If this sounds like a PITA, it is. You might decide you are better off replacing the head with a Byrd Shelix.
eliot feldman
Thanks for the info. I gave up on trying to get through to Delta and found a place with the address eReplacemant Parts.com. instead. The lady there didn't know what a jointer was and couldn't find the parts. (They are the ones you posted here.) But she did save the day by telling me that my catalog number IS the model number. That was good enough because I could then find the proper exploded diagram on their site so I could find the knife adjustment lifter and setscrew on their diagram because I knew where to look. Oddly enough the lifter is called the 'nut'. I ordered it, but it's going to take several weeks because they have to order it from somewhere.
I'll take Bary up on his deal for the knife blades to make a contribution to this site for the blades.
eliot feldman
Yes, I have set these blades exactly the same way. And yes, again, the only hard part has been that the blades shifted whenever I tightend the locking nuts. I didn't think that the reason could have been dirty stuff in there. I will make a point of cleaning everything thoroughly the next time I do it.
My problem this time is that I had apparently not tightened the blades enough, so one of them went loose, shattered, and dinged up the edge of the table a bit. It is all recoverable fortunately. I was lucky that the board I was jointing took the hit instead of me. I did find the parts of the shattered knife in shute.
eliot feldman
This is very good of you. My address is 9311 Friars Road, Bethesda Md. 20817. I will make a donation to Wood Central.
eliot feldman
What a terse reply! And exactly on the money! (I am very curious, if it's not too big a secret , to know your profession -- or former one if retired now. I 'm asking because I'm thinking that only a certain type of of person thinks is such an efficient way. I think it's impressive.)
For anyone who may be following, I had ordered the nut and set screw from eReplacementPars .com. But they take forever; so I found it on Tool Parts who has the nut in stock. But they claim the set screw is obsolete. That's curious because, despite the time delay, eReplacementParts , was going to send it. So , perhaps it is obsolete and eReplacement just happens to have some left over. Or they are mistaken. AT any rate the set screw is just a setscrew, which I can find or make myself.
Eliot, Your knives are on the way. My friend Byron mailed them for me. There are three sets. One Craftsman, one Rockwell, and one I "made"/cut down from a planer knife. Those are larger and may not work, because they may be too wide. I never installed them. I sharpened them before packaging. They are all taped up and double bagged. Did not want them to escape. You may need power tools to get into the package. One set has a tiny nick about half inch form one end. Side slip or misalign then to negate the nick. Hope they work well for you.
eliot feldman
Barry, you are a prince! I will immediately make a contribution to Wood Central.
eEiot Feldman
So, did you have to pay $333.50 for your Shilex ? How hard is it to switch it in? Is it a much better cut? I imagine it would be smooth a silk!
Hey Eliot. did you get your knives?
I mailed them. Really I did. About a week ago. Really
Re: Hey Eliot. did you get your knives?
eliot feldman
Haven't gotten them. Certainly didn't want to complain about it. did you use the right address? --- 9311 Friars Road, Bethesda, Md. 20817.
eliot feldman
Max, my bulldog just started barking at the mailman, right after I answered you that the knives hadn't arrived yet. Well, they are here,Three sets! Just as you said. And your were right: I needed several special tools to open the three carefully wrapped packages. Well not really; but they certainly were well-wrapped. I quickly checked the wider ones that you reduced in size from planner blades , and just possibly, they may fit. Can't thank you enough! And,yes I did make a contribution to Wood Central. Thanks again.
Excellent.....
They went out right before the snow. Maybe that delayed them a bit. Hope they work for you. And thank you for making the contribution. I enjoy Wood Central tremendously and am glad we could help.
Re: Excellent.....
eliot feldman
So, now I have a question: given that I have a choice of three sets of blades -- one very slightly lighter than the delta factory ones, one slightly heavier, and one ( the shortened planner blades) considerably wider, thicker and heavier --- which set do you think would make the better cut -- all else being equal?
Oh, you may have missed my other question: how do you like your spiral cutter head? How hard is it to mount it to your jointer?
Re: Excellent.....
Eliot, I am not an expert, but I know you do not want to mix and match. Keep the sets together so that the blades are all the same in each set, IE dynamically balanced.
An as far as which set to use, lighter or heavier, I don't actually know if it matters. I ran the two lighter sets for years and they were fine. I never ran the heavier set, but would have been able to seat them all the way to the bottom in my head without shims. My head was so old it did not have jack screws so dropping the wider knives in all the way would have been easier, assuming the head was accurately machined.
I have not gotten the new heads yet. Byrd/Shelix has been slower than I thought. I did get a call from them saying they would be shipped in a few days. They are sending me the new head with new bearings press into place. Looking forward to getting it and trying it out. I miss my jointer. The person I deal with at Byrd said they have about a thousand heads going out. Maybe that was hyperbolic but it seemed like a lot to me.
eliot feldman
So,... I installed the set that looked closed to what I had. I works beautifully!
I'd like to turn a little something for you as a thank you. Is the address on the package a good one to send it to? I noticed another name there.
Glad they worked well for you. Enjoy.
Thanks for the offer, but you don't owe me a thing. I appreciate your donation to Wood Central. In case you can't tell, I enjoy this place a lot and like to help where I can, even if its indirect. Thanks for the help.
