OK I'm going to throw away my chisels *LINK*
https://www.youtube.com/watch?v=Hk4cwtQJmwU
Re: OK I'm going to throw away my chisels *LINK*
#2Re: OK I'm going to throw away my chisels
John McGaw
I think I'll just wait until Leigh produces a router jig for it...
#3Re: OK I'm going to throw away my chisels
Some friends recently gave me a book called "The Art of Japanese Joinery". I darn near cried when I read it. T.
#4Re: OK I'm going to throw away my chisels
Larry
All I can say is: Dam!
#5Ok, Brian, Get Crackin'
Here's your Asahi joint. We'll expect a full pictorial, of course.
#6Hah!
Brian Holcombe
Next week....I promise
I've cut the rising dovetail a few times and it is a rock solid joint, and assembles very similarly (from the back of the joint forward at an angle).
These angled finger joints give me pause because they're mostly short grain.
#7Re: Sour Grapes
William Duffield
He could have 3D printed it and painted on faux wood graining.
What did he do that couldn't be done with a tube of CA and a drywall screw or two?
Facetiousness aside, the only things I've seen that come close are a Ming Dynasty chair reproduction by Yueng Chan and of course Chris Hall's "The Carpentry Way".
And Brian is catching up fast.
#8Drywall Screws?
Nah, all it needs is "a couple brads 'til the glue dries."
Glue?
Kneale Brownson
How would you add any to such a tight fit?
#10Re: Glue?
Brian Holcombe
Hah, there may be some truth to that. I've had work tight enough that it squeezes glue from both sides pretty often, and I expect a thin film is left.
I always wonder when I'm wedging tenons (I glue them) and the glue squeezes right off the wedge like a squeegee. Good thing that the tenon itself is nice and tight.
#11Personally
I use epoxy bulked up with wood flour to "fill the gaps"
#12Re: Personally
Brian Holcombe
Hey....sometimes a little glue mixed with dust is needed.....I pass no judgements
#13Re: OK I'm going to throw away my chisels
Joanne in Point Pleasant, PA
I love all the ads for Japanese chisels--as if having those chisels would make it any more likely that I could cut such perfect, difficult dovetails. I'm happy to cut "regular" dovetails and have them come out decent.
#14Re: piece of cake
TomD
I don't think there is any real difference, it is just a dovetail. Well a twisted dovetail. Been covered in FWW and other mags decades ago. Layout would be a pain the first few times around, though all it seems to be is you start with whatever gain, say 5 degrees and just add it to each line.
#15Re: Glue?
TomD
The fit is just hand tight, he couldn't easily drive that joint together with a hammer, so it isn't all that tight. And as Mark pointed out, there is a lot of end grain so you should be able to get a soak going. It is possible to assemble dovetails and then just wick in CA glue for the bond. But the downside is that it doesn't tend to pull the wood together. So for that approach or epoxy which doesn't swell a joint and acts like grease when assembling, it might be best to use woods of two different colours.
To pull the wood together and get some help from your glue you need some white or yellow glue. If you can still find a low tack white carpenter's glue, that would be the ticket. If not, titebond 1.
#16Re: OK I'm going to throw away my chisels
TomD
Speaking of Japanese chisels been using those for 35+ years. You are right, they don't make a carpenter out of you, but I bought them with the assumption I would work up to them eventually, no second guessing. In the case of this joint it would seem to be a case for a fretsaw to liberate most of the wood, and then just chop the shoulders. Unless I was doing a lot of them, I am doubtful chisels would be the best way to root around in those angles.
No Gaps is the video joint.
