Re: Interesting *LINK*
Interestingly, my favorite #3 is a postwar Stanley Bailey, even though I also have a three patent date #4C, a Bedrock #603 and a couple other assorted small smoothers. Other than an aftermarket blade, the Bailey worked perfectly off the shelf at an antique barn.
I almost never use my jack plane.
IMHO, those who recommend bevel up smoothers are in denial.
Hi William
My favourite size is also #3. I have a LN and an English Stanley (that was my FIL's). They are interesting also as a example of the re-emergence of the chipbreaker into tearout control.
Up to about 4 years ago, when we began discussing setting the chipbreaker, the planes I used focussed on high cutting angles to control tearout. As you know, the West Oz timbers I use are highly interlocked. BU planes and woodies with high angle beds were the designs I turned to.
In this time I had purchased a LN #3 with a 55 degree frog. It was not high enough to prevent tearout. 60- and above degrees was the minimum in my experience. So the LN #3 sat on a shelf. As did the Stanley #3, which had a common angle frog (45 degrees).
I began using the LN again when experimenting with the chipbreaker. After a while I decided that the high frog was more of a hinderance than a help, and ordered a 50 degree frog for the plane. Why 50 degrees and not 45 degrees? - well, I did not find much difference in practice, and I could still sit a #4 handle to the LN #3 (whose original handle was too small for my paw). It took a while for the message to sink in - partly because by then I was using the Stanley #3 with a chipbreaker very successfully - and eventually the LN #3 acquired a 45 degree frog. In practice it work no better than the UK-make Stanley (circa 1960, but with a Veritas PM-V11 blade and chipbreaker), but it is nice to hold. I like the extra mass in a small plane.
It's a damn pretty plane ...
The other plane which I rave about takes all this one level higher. This is the Veritas Custom #4. If they had made a #3, I would have purchased that instead, but one is not out yet. I assume there will be one coming along. The Custom #4 is used with a 42 degree frog and the PM-V11 blade. This is such a sweet plane. With the chipbreaker, it fear no grain reversals.
Planing into the grain of some very interlocked Curly Marri ...
Now about that crack at BU planes
They are bloody good. Not ultimately as good as the double iron plane in the hands of someone who knows how to set a chipbreaker, but for someone who simply wants to extract superior performance, a plane such as the Veritas BU Smoother will do everything most users will aspire to. It takes someone a little more gung-ho to use a chipbreaker. The BUS is point-and-shoot.
My restyled (!) BUS planing the same board ...
For those here interested in understanding the ergonomics of hand planes, I have a link below to an article I wrote a while back. Long but lots of pictures.
The Veritas Custom Bench Planes
