Making the O.D. of a router bit bearing larger
Years ago, I bought what I thought was a top-bearing template bit, made by Porter-Cable, on clearance. It turns out it was a special-purpose bit for one of their templates, and the bit, at 9/16", is smaller than the O.D. of the bearing, at 5/8" (these may be approximate measurements - taken with a General Tools vernier caliper, on which I almost never use the vernier part, because I've got a dial caliper for fussy measurements).
No big expense to buy a top-bearing template bit, but my Scots ancestry (1/8 part of me, not much but enough) balks at spending money when I could instead spend hoursandhours making this bit work.
1/4" I.D. by 9/16" O.D. router bit bearings seem to be pretty thin on the ground, but 1/4" I.D. by 1/2" O.D. router bit bearings are very easy to come by, and I need to build it up by only 1/32" (radius measurement). I'm thinking a short section of heat shrink tubing, cut long enough that it slightly overlaps the bearing top and bottom, to hold it in place. Of course, if the bearing gets hot enough, I suppose the tubing could melt, making a mess. Opinions appreciated.
Re: Making the O.D. of a router bit bearing larger
John in NM
Woodcraft sold or sells a set of bearings that have steel sleeves outside to do this kind of thing. Another set I had from a Freud multi-rabbet bit had little stepped washers for the inside.
I'll go look through what I have around and see if any would fit the bill - the Woodcraft set was given to me by a friend who wasn't using them, and I'm not using them either. I'm curious to know at this point if there is any use for them at all!
roger lance
Porter-Cable sells a whole series of router bearings.....speak with your local dealer or internet.
I don't think I have any Scots blood, but I appreciate you frugal gene. I ahve spent many hours placating mine.
I doubt the heat shrink tubing would work. The outer race will spin at whatever speed you are running and I suspect it may just sling the wrapper off. And then when the heat builds up there will be a mess.
Wonder if you could build up the perimeter with epoxy and then turn it down to size?
Bruce, a MN Galoot
I'd be dubious for all the reasons stated above, but what the heck, it's likely you have the stuff on hand, so try it. The bearing stops spinning as soon as it hits the guide anyway. If it stays on, my concern would be that it might not be uniform in thickness. OTOH that might not matter.
Why spend any time or money?
Mark Hennebury
Why not just do a test cut, measure the actual offset and make your template to accommodate it.
William Duffield
I'd start looking here: http://www.whitesiderouterbits.com/catalog.html#catimgs Scroll down to the bottom right corner, and click on "Bearings".
Thanks
Tried that, and other searches. The I.D./O.D. combination appears not to exist.
Probably better just to go with the new template bits.
On which subject: I can get 1", or I can get 3/4" (or I can get other lengths, but those seem like the likely two). Any benefits to either length?
Re: Thanks
Bruce, a MN Galoot
Yes. Get the 1". It's much easier to work with 3/4" wood when you have a little bit of the little bit hanging over each side, rather than trying to cut an edge exactly. You can do it with a shorter bit by moving it up and down and making multiple passes. Much easier with a longer bit.
Hi Bill
I think that modifying router bits is dangerous.
For what it's worth, I have just (literally) received a set of Whiteside spindle and bearings for one of their 1/4" slot cutters (to use in a progressive cut for frame-and-panel building for the kitchen doors I am about to do). I could have got away with 2 bearings, but purchased one extra.
This is the invoice from Highland Woodworking, for your interest.
Agree, and furthermore...couple ideas
When we were using industrial pin routers all the time, we were constantly making custom arrangements, whether it would be turning pins of custom diameters or sizing templates to work with existing setups. If the template isn't too unusual, you could use a 1/2" bearing to make a custom template that is 1/16" smaller than the current one, then use your 5/8" bearing with that template to cut the exact size you wanted to begin with.
PS I've made custom sleeves for bearings in the past, mostly for shimming out the depth of slotting cutters, which customarily are at 1/2", to 1/4" depth. What you want to do is to make the sleeve with a hole that is just a thousandth or so smaller than the OD of the bearing, then heat it until it slips over the bearing, and let it shrink tight as it cools. If you only need a 1/32" wall thickness, that might be difficult. You might want to go to an even smaller bearing, like 3/8", so you can use a thicker sleeve. You could easily get a machine shop to make and ream the sleeve to your specification, even shrink it on for you.
Leaving the cave was dangerous
Mark Hennebury
Curiosity, analysis and experimentation, driven by the desire for a better world, bought us a long way from the cave, thanks to those with the courage to step into the unknown.
It may be dangerous to experiment, but it is far more dangerous not to.
I constantly experiment and modify tools, machines, joinery etc. how else would you learn, understand, progress?
My search for the router bit design for the perfect finish on end grain, and climb-cutting started with standard router bits, then custom made with disposable tips, then custom made with staggered alternate angle tips, then when i couldn't find anyone to make the design that i thought would work, i got blanks made and ground them myself by hand.
I very early on realized that things are not all made the best that they can be; a lot of the time they are designed to be easy to manufacture and just good enough to sell. lots of room for improvement, don't be afraid to experiment and modify.
Life should be a journey of exploration.
God save us from contented man.
Looked through my stash
John in NM
Not a 9/16 OD in there, whether bushed or not, they all go from 1/2 up to 5/8.
Two things you could try, first a bronze sleeve bearing to go from 3/8 or so to 9/16. It would have to be a good fit as most of those bearings are oil impregnated and you can't cheat with some locktite.
Second, you could try to get there from 1/2" with a couple pieces of K&S tubing and some locktite or superglue. Won't last long though, the heat will break down the glue.
Best bet is probably templates with offsets, as Mark and Ellis point out. I'm still a bit surprised that they manufactured such an odd sized cutter though. I wonder if a 14mm is really what you're looking for?
Re: Leaving the cave was dangerous *LINK*
William Duffield
All tools are kits!
Lucy died due to a fall out of a tree.
Australopithecus afarensis
We are all going to die
Mark Hennebury
the question is will we all have lived?
I would rather have a short life of adventure, exploration and danger, then die falling out of a tall tree that i climbed to explore my world, rather than to live a long and safe life in a dark cave, afraid to venture out into the unknown.
Mark, this is part of the reason I specialise in hand tools - I can still move faster than they! :)
AZ in Colorado Springs
I once tried wrapping duct tape on a bearing to reduce the depth of cut on a slot cutting bit. It was impossible to wrap the tape tightly enough to make it solid/ rigid all the way around the bearing and the tape shredded when it contacted the work piece.
Mark Hennebury
I have a lot of scars on my fingers, most from chisels.
