Do the twist!
Do the twist!
Do the twist!
Tony - Memphis
This is a Christmas present for my folks. I'm ashamed to admit it is a copy of a Bombay product. My mom commented on it a couple of times, so I decided to try to make a copy of it for them.
Anyway, it is mahogany. The top and bottom are Honduran and the post is African. I couldn't find Honduran that big. This is my first attempt at a Barley twist. I'm not unhappy with it. Water based dye (a red and a brown), gel poly and wipe on poly, rub and wax. It went to great pains to try and minimize the end grain darkening. The original has a terrible color variation. This pic makes it look a little dark and way more shiny than it is in person. Not sure why the camera did that. It was late in the afternoon and in front of a door....
The top and bottom are glue-ups ~11" wide. Tried real hard to match grain and direction. Lots of times, when you match the grain pattern, the grain direction shows up when finished (ie one side of the joint is darker cause it reflects the light different).
Fun project!
Re: Do the twist!
Beautiful!
Re: Do the twist!
It really is.
Yonak
They're going to love it.
Re: Do the twist!
Re: Do the twist!
Brian Holcombe
Nice work Tony!
Re: Do the twist!
Re: Do the twist!
John McGaw
Lovely work. I tried to do barley twists only one time with a simple set of candle holders and finally gave up in disgust. Sometimes the skills don't measure up to the dreams.
Re: Do the twist!
Re: Do the twist!
roger lance
Tony......I'm guessing you used a turning process to create your attractive table.....if you have pictures of this procedure, I'd like to see them.
Re: Do the twist!
Classic timeless style!
Re: Do the twist!
Re: Do the twist!
Tony - Memphis
I turned the column on the lathe (including the beads),but the barley was done completely with hand tools. I'll try to find some pics. I took a couple. The layout is very important. I used different colors for the various features so I didn't remove the wrong thing. I sawed a cut marking the max depth of the "troughs", then carved away the wood from the peak to the trough all the way around (there are two twists). I used a round rasp to clean up the troughs and chisels to clean up the curves. Took some time. Tried to leave the red lines (at the peak) - that kept the curves and the max dimensions in check. Spent a lot of time looking and tweaking.
Forgive my terminology - I forget the names of the parts lobes, bines, etc. - oh my!
There is some good literature out there on the technique(s). Similar to carving a flame finial. Oh, I used blue painter's tape on top of my grid to lay out the twists - 4 two innies and two outties!
Tony
Re: Do the twist!
Re: Do the twist!
Tony - Memphis
This is the layout happening...
Early roughing...basically cutting a V...
I carved using the "facet" method - this is a template/guide...made many laps knocking off a new facet each lap...if you stay true to the guidelines, the curves almost form themselves... the troughs were almost done here....
I finished up with chisels, scrapers, and sandpaper - I may have grabbed a file and a rasp at some point. Notice the cardboard sleeves over the beads - that was for safety - didn't want any nicks!
Re: Do the twist!
Re: That's really nice
Re: Do the twist!
question
How did you apply the dye? The piece looks uniform in color so whatever you did you did it well.
Thanks for detailing the carving process. I suppose it is easier than it looks when you get into it, but probably not. :)
It's a pretty piece and I'll bet it looks great in service.
