I inherited a Homecraft shaper with 1/3 hp 1725 rpm motor, along with plenty of knives. I'm in the process of rebuilding it and was wondering if it would work better with a 1 hp motor? I've made some poplar moulding but it's underpowered. Anyone tried this kind of upgrade?
If you still think that you need a larger motor then 1/2 hp, you may be restricted with a physical size and weight. You've got to remember that the motor mount was probably designed for a certain size and weight of motor. I probably wouldn't go much higher then 3/4 hp, 3450 rpm if it's possible.
I have the Delta/Rockwell version of that shaper. Bought it in 1971. I have no idea what motor is on it, but I can look tonight when I get home. I have not noticed it being under powered, but I tend to take light cuts and feed slowly. Been happy with it. Have heard that the three wing cutters for it are no longer made. My Router table gets more use these days. I did add dust collection to mine and it works well. Can send you a picture if you are interested.
Joey, thats great that you looked into it. Obviously not only the motor that you have now is a little short on hp, but it's way short on the rpm. What ever hp motor you choose, make sure that the rpm is correct.
Online. Try this. Should have done this from the beginning.
For my money a shaper is one of the machines where one has to be most careful. Be diligent in what you do, the directions indicate a more powerful motor is possible but take care.
Joey, I think the extra hp is safer. Makes for a nice smooth consistent feed. OTOH, a half hp will cut you just as badly. I have never regretted the power.
Thanks again Barry This head and lots of steel knives came with my shaper. You load three of the same blade and let it spin. Are you familiar with this set up or do you use individual carbide shaper knives?blades
Joey, I also think that is for a table saw. I have one I bought many years (50) ago for my Craftsman Radial Arm saw. Used it once, and put it back in the box and in the drawer and its been there ever since. Did not like it. The RAS was not strong enough and it would shake and vibrate.
I don't know what the design speed is for that type of cutter. The RAS and TS run about 3600 and my shaper runs at 9 or 10,000rpm. I am skeptical that it would be safe at that speed. If it were to throw a knife it could be worse than a bullet.
The cutters I was talking about appear to be in the background of your picture. The are one piece three wing cutters about 2 to 2 1/2" in over all diameter. (My friend tells me they are hard to come by now.) I bought a fairly complete set and still have them.
Now for some physics. The cutter head you show is at least twice the diameter of the little three wing ones. That doubles the power needed to drive it. Think of it as a wrench. If you wanted to turn the shaft, or stop the shaft against the motor, would you use a little short wrench or a big long one? If your shaper is running slower, the time between cuts is longer. If you slide the wood by quickly you get a set of little scallops. If you go slowly they become truly tiny and appear to be a smooth surface. If a TSW runs at 3500 rpm and a shaper at 10,000, you can mover the work by at about triple the speed and get the same result. That's disregarding the fact that the shaft on the TS may not e as steady and thus add to the scalloped edge.
Just not sure I would be comfortable running that cutter head on my shaper. Double check to see if it has a speed rating.
I have one similar in function to that but different in construction, Craftsman 3217 Radial and Bench Saw Molding Set, bought 40 years ago.
Yes, it is scary but so is the radial arm saw and the table saw. I cut a LOT of molding with it on my 10" radial arm saw for picture frames and such, using a set of spring clamps to constrain the wood both tight against the fence and tight against the table so there was no possibility of a kickback. Ain't no way I'd use it freehand without the spring clamps! It was also important, according to me, to not try to take off too much stock at once.
There was a small amount of vibration when spinning up as it went through a critical, but this one smoothed out at speed. I also made sure of my position, stance, posture, and clarity of thought before turning it on - just as with other power tools. These days I would use a router table but I didn't have one then.
I also got a lot of use from a dial-adjustable dado cutter. This was great for my use - dial in the desired cut width, no need to remove the nut and juggle shims. Need another millimeter width, no problem, just loosen the nut and dial in a smidgen.
I found this with a picture of both, except this one doesn't appear to come with any molding cutters:
