A55 Smoothing Plane
TS throat plate question
I have a 10" Delta/Rockwell contractor TS I bought in 1971. The throat plate is some sort of pot metal. Its too flexible/sags a bit. How interchangeable are throat plates? Can I buy a replacement that is stronger? Anybody got one they really like?
Re: TS throat plate question
Hank Knight
Barry,
Why don't you make one - or several. Use the one you have as a template and cut new ones out of BB ply or some other suitable material. Clamp the new ones in place, turn on your saw and raise the blade to cut a kerf through the insert. Voila! A zero clearance insert. You can even get fancy and add leveling screws to the bottom. Easy! Probably better than most you can buy.
Hank
make it
I have a stack of home made plates made from what ever was on hand- Corian, 1/2" plywood, Some sort of 3/8" reinforced phenolic sheet, 1/2 polyethylene, etc. There are zero clearance for this and that blade, zero clearance for a particular sized dado cut, not so tight clearance for this and that bade thickness, 45 degree slots, etc. I must have a dozen or more.
Trace the outline on the 3/8 or 1/2" whatever, cut out with band saw, cut the slot with the blade you intend to use. Drill the 4 corners and install 1/4" Allan screws for leveling jack screws. I keep a jar of these allan screws on hand for when I need a new plate for some application.
Ditto
I've made and used a number; probably have 6 for use as "0" clearance with the stacked dado set in various widths, as well as several set up to use with the blade at angles. 1/2" ply does just fine and 4 little holes to take set-screw levelers complete the scene. 1/2" Bakelite is more durable, but you'll have to tap the holes for the set screws. 1/2" Melamine surfaced stuff will give you a smoother surface, but the flakeboard substrate won't last as well.
Old Poly Kitchen Cutting Boards Work
Re: make it
Joseph Mulherin
I agree with Mark and Bill on making your own plates. I made several by using 1 1/2" PVC pipe.
Cut the pipe on the table saw length ways, the heat the pipe in the microwave for a minute.
Remove it from the microwave with gloves and lay on a flat surface to cool....opened up flat.
Then mark your original plate on the pvc and cut to fit your plate size, the insert it into the plate hole and lift your blade to cut a smooth no-lose hole for the blade and your woods. And have several on-hand if any of them are damaged and have different saw blades cuts....such as dadoes.
Re: make it
jerry roberts
I did exactly what Bill did. I really don't use the metal one that came with my unisaw but use only the ones I made.
Hmmm...I made a bunch....
While I was waiting for a response form Wood Central, I was trying to figure out why I don't like them. I made them out of Baltic birch plywood.
They are not as slick at the pot metal one.
If you raise the blade through one and forget, and then try to tilt the blade, not good.
On my saw, the ten inch blade will not lower below a "full thickness" throat plate. I have to install an eight inch blade and raise it into bottom to cut some clearance and then install the ten inch blade to cut for zero clearance.
Perhaps I have gotten lazy and am just bitching. Time to revisit the home made ones. Perhaps Formica on the top and under cut them all to start with. Wonder what it would take to cut enough clearance to allow for angling the blade?
This might be a good time to switch to an excellent 8" blade like the one Bill advocates.
Thanks for the reminder.
jessecloud
If you have a flush trim bit for your router, you can make a dozen in no time. Just rough cut the shape, double stick tape to the original and trim it down for a perfect fit.
I keep a bunch of blanks around and wind up using a few every year. About time for another batch.
Re: Hmmm...I made a bunch....
Bruce, a MN Galoot
Before I got my sawstop, the only ones I had for my contractor saw were from Baltic birch. Worked fine for me.
not difficult
While I have not been bothered by the coefficient of friction of any of the plates I have made, if I did I would wax them.
To cut the slot, stack the new on top of the old. Weight the top plate with either your lead brick or two bags of #5 shot and raise the saw blade up through the new plate until it just emerges. Stop. Remove old plate, install new plate in table saw and raise blade to where ever you might use it. Alternatively, if you used plywood just screw them together. Or a dozen other ways of skinning this cat. Has anyone ever skinned a cat. Why?
I once made a new plate from 1/2" aluminum plate. I milled out the underside so as to be able to tilt the blade. Could do the same with Corian, polyethylene, etc.
Joseph Mulherin
Try my suggestion about using the PVC pipe. If you need the plate thicker then just pvc glue a couple together and bevel the underside for the blade tilting. It works fine and is cheaper than plywood and will not deteriorate quickly.
Jim Dillon
Barry, I've made several from 1/2-inch baltic birch ply. Used the method described by Jesse with a flush trim router bit and using the original metal plate attached with double sided tape. My zero-clearance version is no longer zero, but I am too lazy to make another. I just used a few pieces of masking tape to level the wooden plate. I also just used the TS fence to hold down the plate as I raised the blade to cut the clearance. The only downside is that when I use a blade stabilizer with my plywood blade, I cannot raise the blade to full height as the stabilizer hits the bottom of the wooden plate. Seldom a real problem unless I'm using my TS sled. Haven't seen any friction issues, but I usually wax the plate when I wax the top of the TS. I also had to cut a notch in the rear of the plate to accommodate my Biesemeyer anti-kickback device. And I drilled a finger hole in the plate to facilitate removal. Jim
Re: not difficult
Clifton C
I'm thinkin maybe the swimming kind, Sometimes in the river, sometimes from the pond. I think over the years the "fish" part got left off...cause I know there's more than one way to skin a catfish...
c
Plate thickness
Joe, I don't understand. PVC is only, what, an eighth of an inch thick? Throat plates are 1/2" + . What am I missing? How do you bring it up flush with the table top? Jack screws in the top casting?
Re: Plate thickness
Joseph Mulherin
I don't have the "regular" saws the rest of these people have. Mine is the Shopsmith and a cheap contractors saw for work outside the shop. Plate is only maybe 3/16" thick.
Brad Chenoweth
I've always used my dado stack to cut a relief in the bottom of the inserts deep enough to clear the blade, then finish the cut with the blade I'm making the insert for. Never done one for an angle, but this procedure should create enough clearance for that, as well. Just my .02.
Brad
Re: Cheap Contractor's saw Joseph ?
CharlieL
I'd like to know what it is that you mean. Every once in a while someone miscategorizes a table saw and calls a Jobsite saw or a bench top saw and then calls them a Contractor's saw, even most of the new Contractor's saws aren't even that. And I really get tired of all the Contractor's table saw bashing, not all true Contractor's saws are built equally. In my option Delta / Rockwell HAD the best when they were built in this country. Even the Powermatics were not built as well, their trunions were smaller in diameter.
William Duffield
Well, I wore out a made in U.S.A. 34-444 Delta contractor's saw, due to either excess vibration in the pulleys and V-belt or because the original machining or materials of the axle for lifting the trunnion were sloppy or substandard. It had some other weaknesses, as well. There's no way I'll ever wear out the trunnions or spindle on the cabinet saw I have now. It's built even better than the most robust cabinet saw that was built for a while by Steel City (in China).
Joseph Mulherin
My 'cheap' contractors saw is a RYOBI 10". It functions adequately enough for me, but I can setup and use plywood on the Shopsmith by positioning the tables and legs to hold the large sheets for cutting and not loose the remaining cut offs.
Also, the Shopsmith is my lathe, disc sander, sheet sander up to 30" by using the turning I made and add sandpaper to, can run my planer, can setup and have a large table drill.
You just have to plan on how the saw is setup for the individual usages.
The thing to remember....
John in NM
"cheap" also means inexpensive :D It also describes those of us who only have a cabinet saw because we lucked into one for less than the price of a new contractor's saw.
Before that, I had a "really cheap" Craftsman 8" saw that I won't even dignify by calling it "contractor's". Looked pretty though, it had that circular brushed aluminum they were using in the 50's or whenever - a carbide blade cut as rough as a steel one though, because it wobbled by several thousandths.
I can't recall seeing contractor saw bashing, in general or in Joseph's post. Not everyone likes them, but not everyone likes cabinet saws either. Perhaps a "to each their own" attitude would be the way to go.
Wax
John in NM
That will make all the difference.
We once had one made of wood stick in the saw - it was made in the dry part of the summer and a month later I had to smash it to change the blade.
Melamine makes a good plate, or anything like that. I never have scraps of it though (and I hope that never changes! :D )
I have one of those aluminum ones with the dovetail wood insert, they quit making those 10 years ago at least. Probably wasn't worth the price tag, but I still like it.
Re: Ryobi
For years I worked on the Ryobi BT-3000 10" with sliding table and adjustable fence rails. The saw would do quality work. The dust collection was excellent. It's drawbacks were keeping it tuned and its limitation on cutting power. Very innovative for its time, but not the tool for cutting 12/4 cherry.
Re: The thing to remember....
Joseph Mulherin
Thank you, John, I meant 'cheap' in the pricing I paid for it at HD.
Re: Ryobi Contractor's saw ?
CharlieL
I consider a Contractor's table saw as a table saw that has a removable motor hanging off the back of the saw trunions and a cast iron top. As far as I know Ryobi never made a saw like that. At best what they did make might be categorized as a job site saw. Wearing out a Delta 34-444 ? I've had one for over 30 years and never had the problems that you speak of William. Some times it's not the product thats faulty, it's the users failure to take care of the machine, and or knowing how to use it properly and not abuse it. Not saying that you didn't, but how would I know what some people do to their machines, or who's pushing cabinet saws for a living. I have not had to put a lot of maintenance into the saw that I own, nor have I had to replace a faulty or worn part. You people need to remember these saws were commercial duty and many were sold to the trades people that used them a lot almost daily. If they were a weak piece of machinery they certainly would have never been built as long as they were. The trades would of found something better along time ago. I don't consider todays job site saws as better, just lighter.
