Product Review-Lee Valley Goose-Neck Task light
I use a router for free-hand removal of waste, for example in making half blind dovetails and hinge mortises. Ideally, I like to route to just shy of the scribe line as illustrated in Picture 1 for a hinge mortise example.
If I can get close to the scribe line one paring cut of the chisel establishes the boundary of the excavation. However, to route close to the scribe line requires excellent lighting as shown in Picture 2.
I purchased the Lee Valley “goose-neck” LED light shown in Picture 3 (Lee Valley 15J7701) to see if it would provide the lighting I desired.
I might add that years of previous experimentation did not provide the lighting I sought. The LV light did, as shown in Picture 2, but some annoying problems were in the path to success.
The light comes with a side mount magnet and an end mount magnet and a separate post to stick in a dog hole (Lee Valley 15J7704). The side mount worked to affix the light to the frame of a band saw or drill press to provide intense task lighting to a work area.
The post for dog hole mounting is stainless steel that is not magnetic, for reasons I can not imagine. Hence, the post can not be simply attracted to the light’s magnetic base and stuck in the dog hole. Rather, the magnet in the end of the light must be pushed out and the post screwed to the light, an arrangement that lacks convenience. Then one discovers that the post is too short to be useful in a worn dog hole.
Next I tried to attach the light to a steel post positioned in the dog hole. The force of attraction of the light’s strong magnet as it engaged the steel post shattered the thin (3/32”) magnet insert in the lamp base as shown in Picture 3.
Reassembling the shattered magnet pieces proved impossible. Each acquired a N&S pole that resisted all attempts at reassembly.
Success with dog hole installation came with magnetically sticking the light to the end of a bench dog as shown in Picture 4.
