Stuck chuck question
I bought a Dewalt 3/8 drill at Lowe's this morning. Bought it as a job site beater drill. It has a keyless chuck. I installed a 1 5/8" Forstner bit and carefully drilled a hole through the floor for a pan drain from the water heater. Drilled through two layers of plywood. Now the bit is stuck in the chuck and I can't get it out. The chuck will "click" one click and that's it. You can click it back and forth and that's all.Did not realize it was a dedicated drill. I thought having a chuck meant you could drill several different sizes of holes..
Before I take it back in a fit of pique, is there a trick to this chuck. For Instance, the shack of the bit has a shoulder on it and the shoulder is against the chuck. Does that cause it to seize? Any suggestions? Soner if tapping the bit forward and clearing the shoulder would release it?
Re: Stuck chuck question
Keith Newton
Are you running it in reverse while holding onto it, or just trying to muscle it against the brake?
Spray lube maybe.
Is it a locking ring keyless chuck?
Dick Coers
I've read about them, never used one. I think you slide or release a ring at the bottom of the chuck before it will let you open the chuck.
Re: Is it a locking ring keyless chuck?
Are you saying I should read the directions? What kind of man do you think I am?
It does have a knurled ring between the drill body and the chuck. I have tried holding the ring and turning the chuck. The first time I put a bit in it I held the chuck and pulled the trigger. That did not work well, the chuck was not all that tight and the bit spun or actually the chuck spun and the bit did not. Then I held the rig and turned the chuck. It clicked several times. I drilled the hole and now I can get it loose. I am suspicious the bit slid into the chuck and the shoulder on the shank cam to bear on the "nose" of the chuck and will not allow the jaws to advance, if that makes sense.
I would read the instructions, but they are out in the truck and it's raining and it has been a very long day.
Matt Robinette
I would try a bit of 3 in 1 oil and patience then spin it fast while in reverse it works on mine when it does that although there may be a different way if I were to read the directions ,,hmmm
Or call M&M tool
Matt Robinette
Woodcentral's newest sponsor :D maybe they will read the manual for you?
Jerry Nicholson
My very first drill had a self locking chuck and had a knurled ring set back a little from the bottom of the chuck. The instructions said "never use tools to unlock the chuck". Almost every time I used it I had to use a pair of pipe wrenches to unlock that chuck. I haven't used it for a while but it still runs. This is a Cummins drill with a Jacobs chuck and a completely non standard spindle. I bought it new in 1948. It was a long time after that before I bought another drill with a self locking chuck!
Jerry
William Duffield
It's a shame they don't make them like they used to. I had a 3/8" DW with a keyless chuck for almost 20 years. The chuck worked flawlessly. I never had to stop and twist the chuck to either tighten or loosen it. I just grabbed the chuck with one hand and spun it with the power switch. I could swap bits faster than I can with my Festool Centrotec chuck, just using the forward and reverse buttons and trigger with one hand and the slightly ridged grip and bits in the other. It was the only chuck I found really comfortable to use that way. I finally got rid of it because I was tired of replacing batteries annually at ever increasing prices.
The shank of the bit being against the chuck should not be a problem. The "fingers" of the chuck retract into the chuck when opening so would be moving away from the shank.
However I am not familiar with that chuck, I have an old cordless DeWalt with the key-less chuck but it did not have any "locking ring" and released normally.
However I have a Powermatic Woodworking Drill press with a key-less chuck. It is nothing but a pain. It has several tool marks due to using Channel lock pliers to release the darn thing every time I drill a hole that requires a bit of torque. That Drill press sure has not satisfied me! For a $1000 drill press it is very noisy, chuck has fallen out several times (I had to polish the Jacobs taper shank to get it to stay. I sure wouldn't recommend it to anyone.
