screeching table saw
eliot feldman
When I lower the blade on my Powermatic 66 TS, there's a fairly loud screeching sound. I suppose I have to get in there and clean and grease up those gears that move the blade up and down. I'm not really sure how to go about it, though. What cleaner and which grease?
Re: screeching table saw
William Duffield
If you think your PM cries out in anguish, wait until you hear an industrial SawStop. :) Mine groans going up and down. Of course, the SawStop has a lot more weight to lift and tilt than the PM.
You might consider lubricating with PTFE or a dry silicone lubricant instead of a grease. Greases tend to attract sawdust, which clogs the gears, so you have to clean them out more often. But, a lot of people will tell you that you shouldn't bring silicone anywhere near your shop, because it causes fisheye in lacquer.
Wax instead of grease
John in NM
Lube the ways that the arbor trunion rides on with paste wax and you'll be all set.
Yes,the squeak is likely coming from the trunnions
Yonak
IMO
Sometimes it is the bushings
Keith Newton
Where the crank shafts go through the stand housing, so spray lube is needed there.
I just rebuilt the older Grizzly Cabinet saw I bought. I put penetrating oil in all bushings. sprayed it in worked the trunions until it was good and free and then wiped it all off. I cleaned the gears with a tooth brush and brass brush and wiped down all the gear racks with paste wax. I replaced the bearings. One of the 3 pulleys was ruined. Had trouble getting the right part from Grizzly because there isn't any model number on my saw. I decided it would run just fine on 2 belts so I turned away the outer surface of the worn pulley on my metal lathe. It works like a new saw now. I ripped full depth of cut maple without any problem. I figure if it becomes a problem I'll pursue buying the new pulley later on.
eliot feldman
I feel fairly inadequate about what, I believe, ought to be a simple enough task. I have used a toothbrush on the worm gear parts, but there's so much dust and junk that I don't believe I did it very well. Is there some stuff I can spray on there that would really dissolve most of it away? I find it difficult to actually reach in there very well. But I am loath to try taking anything apart. I did pull off the wheel and applied some oil at those bearings. but it still screeches on the way down-- no screech going up for some reason.
William Duffield
If you want to spray, I would do it in three steps:
1. WD40
2. Compressed air (use full eye and respiratory protection. You don't want the lubricant or the gunk in your eyes!)
3. A dry lubricant of your choice. In other posts, we've already given you a few good recommendations. Silicone and PTFE lubricants dry immediately. Paste wax takes a while longer while the solvent evaporates, and would benefit from wiping off the excess after application.
eliot feldman
I did what most recommended. It works fine now-- no racket when I lower the blade! The hardest part was dragging the air compressor from my lathe over to the table saw. It's heavy for me, and I'm getting older!
I ended up using some kind of teflon spray that used for bike chains. It seems to work great. I'm sure white grease would have done fine, also.
Thanks to all.
No....
...white grease would have not done fine. It would have attracted dirt and promoted wear. And that is the reason why we learned to use past wax in the Delta maintenance class I attended. It dries hard enough for dirt to not stick.
Glad it's working.
You might consider getting an air hose long enough to reach anywhere in your shop. I got several hundred feet of hose so I could run my air nailers even on outbuildings at the farm here without having to run a long extension cord on a portable compressor. It's nice to have air all around the shop and barn too.
eliot feldman
Why didn't I think of that?
Re: No....
eliot feldman
Then I guess I lucked out with the teflon spray. I had got it into my head that someone had suggested white lithium grease. And that's what I almost bought at the BORG. The teflon seemed a better idea. Lucky!
Thanks!
Re: No....
William Duffield
You didn't luck out, unless you didn't read the label on the chain lube :) Teflon is a brand name for PolyTetraFluoroEthylene, or PTFE.
I find my compressor to be useful for a lot more than power sanding turnings and blowing out hollow forms. I just put a new roof on my shop, and my framing nailer and roofing nailer were indispensable. You need to get a longer air hose.
Teflon fine....
but it will not last as long as the paste wax. On the other hand it is easy to apply. In any case, when it squeaks, add something.
William Duffield
A small portable compressor can be useful, too. I have a very quiet Rolair JC10, recommended by experts here, and it doesn't scare the bench dog like the big one did. There are trade-offs, however: It won't keep my Grex orbital sander running continuously for more than a minute or two. >(
Re: No....
eliot feldman
I learn a lot on this site. So what's the problem with PTFE? Should I get rid of it? Can I apply past wax over it? This is getting to be a headache!
I will get a longer air hose.
Re: No....
William Duffield
There's nothing important wrong with PTFE, unless you heat it over 600°F. As Bill notes, you can use it instead of wax. You should be able to find it cheaper at your home center for lubricating such things as aluminum windows, and it should be cheaper than the same stuff labeled Chain Lube at a cycle shop, but not cheaper than paste wax.
Nothing wrong with it...
John in NM
He's just kidding you since it's what he recommended earlier :D
It'll work fine, just may not last quite as long as paste wax. Ease of application could easily make up for that however. Personally I like PTFE dry lubes - I suspect chain lube still has a light oily carrier, dry lubes will have some kind of volatile carrier that fully evaporates.
Re: Nothing wrong with it...
eliot feldman
I still say that I lucked out because I had forgotten that he recommended it earlier; my mind wanders.
Grex 2" ROS
I bought the angled Grex on recommendation of Rudy Lopez and I am so glad I did. I hate power sanding on woodturnings with the rotating disks but this gives good control. For some reason my 5hp 60 gallon IR compressor seems to run it ok. :-)
A couple of people in another forum said they didn't like the Grex since it stalled easily. Huh? I haven't stalled this one - have you experienced that? I wonder if these guys thought it was supposed to rotate like a drill since it will spin if you start it in the air.
If anyone hasn't seen these:
https://www.amazon.com/AOS368-2-Inch-105-Degree-Random-Orbital/dp/B000HFPDJQ
Re: Grex 2" ROS
William Duffield
I like mine. It stalls when the compressor runs out of air. Doh! I suspect the guys who complain about it stalling are not paying attention to their pressure gauge.
I would suggest that anyone who stalls a ROS is just pushing too hard, which is not what H&L abrasives are designed for, because it tends to melt the hooks and the pad, load up the paper and prematurely wear out the abrasive.
The only issue is that the capacity of my compressor, a wimpy 2.35 CFM @ 90 PSI, with a 2.5 gallon tank, can't keep up with the sander. Woodcraft recommends a MINIMUM 60 gallon air tank for the AOS368. I have the same problem with my Grex MR368 die grinder. If I were going to make extensive use of either of these tools, I would get another huge compressor and tank and put them in a soundproof outbuilding or teach my dogs to wear hearing protection. :)
Re: Grex 2" ROS
Stuart Johnson
Does your compressor cycle on and off or just stays on to keep up?
Re: No....
eliot feldman
The stuff I used is called, "Blaster, Chain & Cable Lubricant". in extremely small print, I see the term,"fluoropolymer". There are all kinds of warnings about not breathing it, etc. But I don't see the PTFE notation anywhere.
