Freud LU73M012 circular blade
ChuckInND
I just got a deal that I couldn't pass up from a retired guy thats thinning out his shop on one of these 12", 72 tooth blades, brand new in an unopened package.
ChuckInND
Re: No one has any experience with this blade ?
Re: Freud LU73M012 circular blade
I have several Freud blades. I have no idea what product number is assigned to them. I like all of mine.
Dave's Not Here
I too am very happy with all of the Freud blades that I own.
Tell us about the deal and what you intend to do with this blade. Is it for a table saw? Is it for a chop saw? What is the tooth angle?
ChuckInND
Well, I looked the blade up on the internet before I bought it, and about the best price I could find was $90, some wanted $100- $120 for it. I bought it for $25. I'll be using it in a DeWalt 12" miter saw. The 12-inch Freud LU73M012 Cabinetmaker's Crosscutting Saw Blade is designed to meet the high-volume, high-performance needs of industrial cabinetmakers. Featuring a tough steel body with laser-cut, anti-vibration slots plus 72 teeth in an alternating-top-bevel configuration that's ideal for crosscutting, this blade delivers both precision and durability. It also offers the strength and sharpness of TiCo high-density carbide tips and Freud's antifriction, antibuildup Silver I.C.E. coating.
John in NM
I really like their 8 1/2" SCMS blade, though like some of the others here I don't pay a whole lot of attention to their stock numbers. When buying a blade I'm looking mostly at width, diameter, and hook angle. To a lesser extent tooth grind, but that is really more a matter of avoiding triple chip grinds and other specialties that aren't something I need at all.
Ah, Chuck
You getting paid to write that or are you about to get hammered for copyright infringement?
PS
Unless I miss my guess, that's a RAS blade rather than an SCMS/chop-saw blade. Shows a 10° positive hook angle rather than the negative hook used in chop saws.
William Duffield
I didn't realize at first that you were looking for comments, and I could not use that blade myself.
If you were a regular commenter on the Hand Tool Forum, I might have replied, "You Suck!" which is galoot-speak for "That is a gloatable acquisition, at a gloatable price."
I'm afraid I don't even have a saw that will accept a 12" blade. I don't have a chop saw or SCMS. For my 10" tablesaw (SawStop doesn't make a 12" saw), I'm usually too lazy to swap between dedicated crosscut blades and rip blades, so I use a combo blade. My favorite is the Freud F40. It works well for the solid hardwoods I usually build with. If I were using more fancy veneer cabinet grade plywood, that would be a very tempting blade, but mostly I use a track saw for breaking down sheet goods, and it takes a metric blade. I do use a Freud blade with a similar configuration on my radial arm saw, but it is underpowered and accepts a maximum 9" blade, and the only one I could find from Freud was 8". I chose it more for it's less aggressive feed than for the smoothness of its cut. I try to limit my use of the RAS to breaking down (crosscutting) rough lumber.
I sure wouldn't say so...
John in NM
Not for a RAS in my book. They also benefit from a mild or negative hook, a medium positive hook angle like 10 degrees and the saw is apt to charge you
At least with a SCMS you can bring the blade forward, chop down, and push it back. Positive hook blades work ok doing that, but I still don't like them on any kind of saw that has horizontal motion of the blade itself.
I would call that a regular chop saw or large table saw blade myself, on either of those the positive hook will just make for a quick, easy cut rather than an unpredictable saw.
YMMV of course, more than one way to chop a board after all
Entirely Possible
That I have my angles reversed, but the Jesada blade (96 tooth - ATBR full kerf) I have on my LS-1211 is a 5° negative hook and its cuts are almost polished it's so smooth.
Negative hooks have uses about anywhere
John in NM
And do give you a nice polished cut on chop saws and table saws. They also require a bit more effort to push the blade through the wood, so they are not always the thing you want.
On a RAS, I take them to be a necessity because they are so unaggressive.
ChuckInND
What I found out is that Freud says the blade is for Slide Miter Saw,Table Saw,Radial Arm Saw,Portable Table Saw. The DeWalt miter saw that I have is a non-slider, so I sent them an e:mail asking them if I could use it in a non-slider, if not, what other blade would they recommend.
Re: Ah, Chuck
ChuckInND
Don't start Mark, I get it. You don't appreciate the time and effort that I put into dust collection improvements. Don't worry, I won't bore you with any more.
Nah, Chuck
Long past time to give up the "I'm a victim" routine, Chuck. It was quite obvious that you copied and pasted that blurb, most likely from an on-line tool seller's description page.
How you collect your wood dust is both irrelevant and, since it appears to be a sore spot with you, a subject which I fully intend to avoid.
My post was a joke.
Get over it.
Dewalt 12"
miter saws come with a 5° Negative hook angle as are their replacement blades, according to their web site anyway.
10° Positive hook blade will be more aggressive and won't give as smooth a cut face, but should work. Remember to back up your cuts if you want a clean edge.
Re: Nah, Chuck
ChuckInND
Yeah I pasted it. It was a lot easier to do then try to remember what all the manufacturer had to say.
Re: Dewalt 12"
ChuckInND
Thanks for the info, I learned something today. Now lets see if I can remember it.
My take
You got a great deal on a general-purpose blade, Chuck. It'll work fine on a tablesaw, standard chop saw or sliding compound miter saw but on the latter I strongly recommend pushing it through the work as opposed to pulling it out through the work. Positive rake blades are prone to self feeding, so I wouldn't recommend using it on a radial arm saw.
A 72-tooth ATB blade is not the ideal configuration for efficient ripping or fine crosscutting; more for a blade that will do just about anything pretty well. Crosscut saw blades cut smoother with more teeth and with teeth that are ground with very little side clearance, such as the Forrest Woodworker II and the Freud LU84. The tradeoff is that they gum up more quickly, which is why professional shops and industrial users stick with standard grind blades, with more side clearance.
Re: My take
ChuckInND
Ellis, the funny thing is that Freud does recommend it for a radial arm saw, along with other types of saws. They do not mention using it with a non sliding miter saw, so yesterday I sent them an e:mail with a question about using the blade with one, and I'm, surprised that I have not heard anything back from them yet, which would be almost 2 pm central time the next day.
Recommendations
Unless a blade is specifically designed only for a particular function, it can be used for other functions as well, with differing degrees of utility. Blade manufacturers often (usually) "recommend" their blades -- especially general purpose blades -- for several uses, even though there may be less-than-stellar performance in those tasks. Some companies state whether a particular blade is excellent, good, fair, or not recommended for the various uses. My own preference, based on some alarming experiences with positive hook blades on radial saws, is that I don't use them except as a last resort. That's a pretty lukewarm recommendation.
Re: Recommendations
ChuckInND
Don't get me wrong Ellis, I do value your opinion. One of my concerns was using a blade that may be more likely to cause a dangerous kickback with a machine, and or makes terrible cuts. If that were the case, then I wouldn't even open the package, and I'd just resell the blade.
Maybe NOT *LINK*
You can download the manual for your saw from DeWalt which seems to state, upper right of page 4, not to use a blade with a tooth angle greater than 7°.
Link will save you the hunt.
Dewalt Manual
Re: Recommendations
John in NM
I once used a RAS that a buddy had thrown a 7 1/4" framing blade on (about a +20 hook). Maybe I should say used once
I would certainly use Chuck's blade on a regular chop saw, should work just fine - as you say, as a general purpose blade. For the price it was a great deal.
I looked at my slider blades yesterday - they're all +10 too and work fine. I always push cut - had the blade come loose way back when I first tried pull cutting.
