I've had this Milwaukee Close Quarter Drill with 1/2 chuck for several years. after a careful learning curve-ie unplug the thing when tightening/loosening the chuck because the torque can break your fingers if you accidentally hit the trigger
Well I think my son burned the windings by running it on long thin gauge ext chord--at any rate it doesn't run any more -When I looked to replace it I see They no longer carry this in a 1/2 chuck-just 3/8 inch. I really want the close quarter aspect- and I like the chorded versions I' don't like have to remember to recharge the battery or get two.....
Any one recommend another option?
My priorities are
1. Close quarter aspect
2. Good torque
3. 1/2 chuck and Not Keyless
4. Prefer tails (no battery)
I am "willing" to go with the 3/8 chuck if other three categories are satisfactory..
Have the motor repairedt? Don't forget that the most common failure of universal-motor tools are the brushes and commutator and general crud buildup. If repair can't be done economically, find out if the chuck from the old one will fit on the 3/8" model. Chucks are invariably removable although the manufacturers seem to go to great lengths to make it difficult and once removed there are only a certain number of variations of how they go back on. I'd think that if the manufacturer was the same and the style was the same the chucks have a good chance of being interchangeable.
What are the symptoms? Does it hum, try to run and can't, just no response? I would certainly take it apart and trace the power from the cord to the motor. And yes, check brushes.
Don't know about a small tool like this but having a motor rewound often costs less than one might think.
I once decided I should blow out the sawdust from mine. When I went to use it nothing. I guess I must have blown a connection loose. I took it apart and couldn't see any issue. When I put it back together it ran fine. I figure something must have been loose enough to not work but still in place.
In any event if you decide to work on it take a photo during each step. The wiring and so forth are all placed very precise and a bear to get correct from memory.
That is the old Sioux angle drill - I wonder if they're still making it for Milwaukee or if they sold the design.
I would first look for a replacement switch for it. I've replaced the switch in my Milwaukee hammer drill twice now, they do wear out. The cord probably had nothing much to do with it, but the switch would suffer before the windings if it were passing too much current.
Alternatively, you could take a look down inside the chuck and see if there is a screw head in there. A tool that small the chuck is likely held on with a screw. You might just be able to swap chucks from old to new - though I seem to remember Sioux having two sizes of those little drills.
They are a wonderful tool, I wish I'd bought one years ago.
There have been discussions on the Turning board over the years about this very model (I have one myself), which is a preferred tool for sanding on the lathe. The dust gets into the motor housing and probably the switch contacts as well. I'd try compressed air before escalating the situation.
Some times the commutator will get stuff in it brush dust and the likes and needs to be cleaned out. Twap it a few times a twap is harder than a tap but less than a hard rap.
Thanks for all the ideas- I did take the cover off and blew the innards out with compressed air and messed with contacts.Still no worky. We used to have a great small tool repair shop in Ann Arbor- it closed its doors a couple years ago...sigh
Alan, too bad we don't live near so I could get that in my shop for an exam! I even have an identical model here to compare. I have never taken one apart but have repaired many similar things - it should be relatively easy to at least find just what is wrong.
Someone on another forum has a problem with a similar drill, but a cheap one from Harbor Freight. His works sometimes and not others. This is what I wrote to him:
__________________________________________
Join Date Feb 2008
Location E TN, near Knoxville
Posts 999
Quote: "...It goes back and forth from working and then not at all."
An electrical problem like that is sometimes very easy to fix. Sometimes a bad connection. Sometimes dust in the switch. Sometimes whacking it with a mallet fixes it.
I would definitely take it apart, blow out the dust, and inspect each connector of each wire for looseness. (Grab each crimped and push-on connector and see if it is loose anywhere.) Look at the brushes as mentioned, clean the commutator. Use an ohm meter/continuity tester to be sure the switch functions flawlessly. The switch is often the problem. Bad solder joints are occasionally a problem in cheaper things. Check the continuity in the cord - the wire can break inside at the plug or at the tool and it can work intermittently depending on how the cord is flexed. (Flex it while plugged in with the trigger pressed and see if it runs and quits.)
Only do the following if you are comfortable working with 110v since it's easy to die or at least make some sparks and fire if you do something wrong: you can apply power while apart and trace the voltage from the plug to the motor.
