Perfromax thickness sander crowned wheel
I was thinking about adding some layers of tape to my front roller to crown it to see if that would make my belt track correctly. Like Barry and others I've tried just about everything. I was thinking (I know that's dangerous) that rather than put gummy tape on there that may come loose over time, would Bondo be better. I can coat it most of the way and after it hardens put in on the wood lathe and turn it down so it has a crown in the middle and tapers out to nothing about 8" in both directions. My metal lathe isn't long enough and I know I can do it on the wood lathe by putting one end in a chuck and make a jig for the other end in the tailstock. This would be more permanent than the tape and easy to remove if it doesn't work. So here's the question. How big of a crown. Would 1/8" thick at the center be enough. I've worked with a lot of crowned rollers over the years but never actually measured any.
Re: Perfromax thickness sander crowned wheel
Re: Perfromax thickness sander crowned wheel *LINK*
Hank Knight
John,
If tape would be easier, take a look at this vinyl tape. It bonds to itself, but not to anything else, so it doesn't leave a sticky residue. It stretches, so it grips securely and doesn't slip. I've found lots of uses for it in my shop.
Vinyl Tape
Doubtful
John, Bondo's not a particularly strong material and will be likely to crack and crumble under the constant tension. You'd be better to used one of the epoxy paste products like "Plas-Steel" or similar stuff they sell at the check-out registers in auto parts stores.
That belt is not under that much load
Dick Coers
I can't see bondo cracking. I'd think 1/16" thick is plenty, but I'm guessing that you will reduce the contact area so much with a crowned roller, you will lose drive. The belt on mine is so stiff, I don't see it touching much more than the very center of the crowned roller.
JB Weld?
Yeah, but
I think a wrap of duct tape would be just as good and far easier to remove if it didn't do the job. If the tape crown worked to "center" the belt, redoing with a more permanent application like a epoxy compound trued up on the lathe would be warranted.
For what this is worth here,
Keith Newton
When the rubber fell apart on the drive wheel of my edge sander, I was really needing it sooner than I could send it off and get it back. So in a pinch, I needed a way to provide something for traction on the slick wheel. After cleaning it up good, I think I may have held a coarse disk grinder against it while it was coasting down. Then I sprayed it with high strength contact cement, then waiting for it to dry hard before putting the belt back on. I've only had to re-coat it once in probably 5 years.
I bought the film backed belt from Klingspor and seem to have gotten it to track. I have to watch it closely. It was tracking toward the motor VERY slowly. Took it an hour and a half. I loosened the rollers and slid it back away.
One thing that helped was to put a second nut on the end of the adjustment screws. Its not necessary, but it serves as an index point when re-tightening the belt. So I can loosen the belt, move it and re-tighten it in a minute or two.
I would try setting the side away from the motor at least a turn "longer" than the motor side. And I would try tape for a while if you feel you must crown the roller. I would put on three wraps of duct tape at the center and 2 on each side and then 1. Be sure the tape does not cause a bulge above the level of the table. Don't want whatever you are sanding to have to ride up over the bump.
I almost nothing about Bondo but I suspect it would crumble over time. Also, I woudl be reluctant to grind the roller without being sure I could get or make a replacement.
Be careful positioning the belt. I started with mine too far away from the motor. I think it scrapped against "things" underneath the table and damaged the edge.
(I am considering putting a five HP motor on both the belt and the drum and sanding both sides a once. Not)
That explains one thing
Dick Coers
I've never run mine that long (90 minutes) at any single one time session. How many times did you have to change the paper with that much sanding? I've never used it like a wide belt sander.
Re: That explains one thing
I ran the sand paper for about and hour. Used the Zirconium stuff that Klingspor sells. Very light passes and sanding cherry. About half that time was wrestling the panels around.
I built and sanded a heart pine side board. (Were you the one posting the picture the other day? Garrett Hack did it in Fine Wood Working) On that project I could barely sand a single piece before the sandpaper clogged. I learned a lot about soaking the strips to clean them. Had to have about ten strips with half of them soaking in Simple Green.
I have a friend with a 3' wide belt sander, but he is an hour away and it turns into an all day visit. And he won't accept payment fo the sand paper.
Matt Robinette
I think I would revisit the tension of the belt ,on mine I can lift the belt from the outside edge and just fit my fingers to between the first and second joint. I work in machine maintenance and have had to track belts from hundreds of yards to less than a foot. There is a sweet spot that the machine has to track the belt, sometimes it is confidence and patience and not going off the reservation, small adjustments and sometimes it is just a nudge. I would start by removing the assembly check the crown on the rollers,it should be hardly noticeable. Check for bent deck make sure your assembly is not twisted it is not uncommon. Reassemble making sure it is square just like you would a box corner to corner. I would like to think the machine is heavy duty but it is not and after a hour or so it may heat up enough to change shape of the sheet metal deck and throw the tracking off. Kinda like in Goodfellas when they shot Tommy for killing Billy Batts and they told Jimmy there was nothing they could do about it and that was that.
thanks for all the suggestions
My Dad finally passed away after months of illness. Once the funeral is done I'll have time to actually get back to woodworking and possibly finally solving the problem on the Performax machine Thanks for all the tips and suggestions. When I get back to fixing it I will pass on what worked and what didin't.
One thing I've been doing while having to use it with the belt still tracking wrong is to get a couple of inside calipers and set them to the gap created by the tensioning bolts. This way when I have to loosen them so slide the belt over I can move them back to the exact tension and readjust slightly to try and fix the problem.
