Re: decks
Bill Howatt
This house has had 2 wooden decks, one spruce and one cedar. The life-span was not really that different between the two. Problem with the cedar one (I didn't live here when the spruce one was present) was nails driven through the top of the boards into the joists which trapped water and caused rot. Redoing the staining was a job.
I put on an addition which modified the deck shape and I used Trex. It is probably close to 10 years old now and apart from the dark brown color fading a bit it is still like new - no cracks and splits.
I spray it with bleach once or twice a year typically and rinse it off. In the winter I shovel the snow off with a plastic snow shovel.
I could have gone with 16" joist centers but for very little extra cost went with 12". One deck is very low to the ground so I used stainless, trim-head screws which I screwed in without a pilot hole and then hammered the raised composite back over the head which effectively hides it although you can see subtle bumps when it is wet.
When I bought the Trex there were few other options in composite around here but that has changed now but I would still go with a solid product. Yes, it is not cheap to purchase but I think the life will more than compensate for the initial cost.
If you don't like the thought of composite, have a look at Ipe which is a popular wood for longevity (apparently).
Bill
