Minimum digning table With????
Jesper, Denmark
Jesper, Denmark
I am moving to a new apartment and have to bulid a new dining table. The space is limited in the width, but not in length. So, what is the most narrow functional dining table?
30 inches are just doable, but a couple of inches narrower will greatly enhance the passage space on both sides of the table.
Re: Minimum digning table With????
Have you considered using a bench on the wall side? Might save some space.
Measure your plates and consider how much room you will need for serving dishes, unless you serve from a side board. You could consider sort of alternate seating if the length is no object.
Dick Coers
Minimum? I use my lap more and more as I "relax" in retirement, so I'd say that is the minimum. How many are you planning on seating? If you alternate the seating so no one is directly across from each other, I bet you could get by with 24".
I have certainly shared tables at restaurants that were less than 30". Cut a piece of plywood the width of your dreams and try living with eating off it. That test will be most relevant.
William Duffield
According to the book "Human Dimension and Interior Space" the minimum is 36 inches.
http://www.amazon.com/Human-Dimension-Interior-Space-Reference/dp/0823072711?ie=UTF8&keywords=human%20design%20interior%20space&qid=1462922616&ref_=sr_1_1&sr=8-1
don stephan
There may be two different questions. What is the generally recommended minimum width? As noted, probably 36", with 42" for reasonable functionality (room for shared items like serving dishes, condiments, milk jug or wine bottle, et cetera). What is the minimum you can live with? Bill's suggestion is right on the money.
Jerry Gibbs
Many yachts have narrow tables that function well.
The other thing to think about is under the table. And What is the function of this table. If it for lunch with only a few people present for a quick meal or for a longer meal with more people and conversation? The alternate seating suggested above might solve the problem of kicking each other in the shins. Bill has a good idea, but you should take it a step further and perhaps set it up in the room with dishes and serving plates and several people. Cooks get to eat their mistakes and builders get to live with them.
27.5" (700 mm)
GolfSteve in Calgary
I have a long narrow dining table that I bought from Ikea. Dimensions are 27.5" x 90" (700x2900). It can seat 12 people uncomfortably or 10 comfortably.
I normally have this table pushed up against the wall, and my family of four eat on one side or sometimes one person sits at the end.
My observation of this normal situation it that while having the table pushed up against the wall frees up room in the kitchen, it is not an ideal way to have a family meal as we are sitting side by side and do not look at each other as we speak and eat. I would prefer to have a small square table for day to day use, and pull out folding tables for big meals.
I have used this table for numerous large dinners (>20 people with folding tables). My observation is that a table 27.5" wide leaves sufficient room for people to sit and room for their plates and glasses, but does not provide sufficient width to also place the food dishes on the table - the food has to sit on the stove or kitchen counters.
Re: Minimum dining table width.....
roger lance
I think you should consider making a table with folding sides......then you would have a narrow table to accommodate traffic with the leaves down.....and also have a sizable table width when needed with the leaves up.
Jesper, Denmark
Re: Proposed solution ... thanks guys...
Jesper, Denmark
Thanks for all the interesting input.
I am proposing to build a 53 x 28 inch dining table with pedestal feet. This will be placed across the space, against the wall opposite the kitchen. This allow plenty of dining space for two, which is the case for 95% of the time.
I will then build an identical table as a work table in the spare room, so when entertaining, they can be put in extension of each other, turned 90° from normal. This should provide ample room for 8 diners and slightly cramped passage behind chairs, which is OK under those circumstances.
I have sufficient 6/4 Black Locust boards to make both from the same glue-up.
I am also considering smoking the locust with ammonia. It has worked well on small bowls. Whaddaya think?
William Duffield
Have you seen the table design with the folding card table top that rotates 90° when opened to give twice the depth (for people on both sides and room for serving dishes, etc. between)? By "card table" I mean the traditional style with two leaves of the same size, with hinges between them. The whole top rotates horizontally 90° and when closed, the second leaf lays on top of the first leaf.
Here is a drawing of the geometry, but regrettably, without the hinges positions:
Jesper...
...would you mind checking your email address? Go to the Preferences link and make sure your email is correct. Your notices are bouncing. Maybe it is just transitory.
Jesper, Denmark
Re: Jesper...
Jesper, Denmark
Hi Ellis, other than the "j" is shown as a capital letter, which should not be a problem, the address is correct: jgronvaldt@gmail.com
