Somebody saw me use an empty bottle for a funnel and thought it useful to them, so I though someone else might find it helpful, presuming there is anyone left that changes their own oil. After changing oil I keep an empty bottle to use as a funnel for the next change.
I use 100% synthetic oil. Saw an industrial demonstration with three engines mounted on engine stands, running until warm, stopped, crankcase drain opened, restarted without oil, run until seized! Block with synthetic oil ran for three minutes longer the others. I realize that tricks could have been used for the demo, but it was pretty impressive.
Bought a 1980 F-100 with big V-8 in1984. Changed to full syn oil and picked up 10% mpg on the first tank full. A 1995 Subaru developed a rear main seal leak @100K. It would blow two qts in the first 15 miles after an oil change. Changed to full syn and added another 110K until 2006. That engine livid with two qts missing from a 4 qt crankcase. The extra price is well worth it!
I have a large funnel that holds 3-4 containers that drain into one. Every oil change gives me about 1/8- 1/4" of drippings. The extra goes into a container for chainsaw bar lube.
My wife would love to have something like the oil drainer for her shampoo or lotions. She saves the empty bottles until she has several and uses the microwave to heat them a bit then combines in one bottle. Four or five bottles will net around a half bottle. Her motto is "I paid for it all and I'm going to use it all".
I save the drained oil and use it for bar oil. Modern oil is a bit thin so one uses more of it...but its cheap! In 20+ years I have seen no ill effects of this frugality either with my professional grade Stihl saws or a smaller saw I pack to remote locations.
Had your well tested lately, Bill? You might be surprised to find traces of the Round-Up your neighbor used, not to mention the lube from your chainsaw.
Before it was in your oil can, it had been in the ground for as long as hundreds of millions of years. I wouldn't call that biodegradable. I know that they are working on GMO microbes that they claim will eat it, but those are a lot more specialized than what you will find in the soil in your woods.
That might be a good plan here too - pinon and juniper stretch chains like nobody's business, and the sand wears bars out fast too. Lots of thin oil might just improve my chain & bar life by washing some of that sand out. Sand is in the bark mostly.
For perspective, I have stretched a 16" chain out of adjustment in a single day in the summer before. Bar on that saw lasted one summer.
Up at work, its mostly ponderosa pine, spruce, and some kind of white pine. Those cut much more like what I remember from my youth in Maine - rare chain adjustment rather than on every tank of gas.
....the degradation of oil buried and anaerobic might be substantially different from oil dispersed in wood chips with plenty of light, oxygen and bugs? What do you think happens to all the oil that has dripped from cars in the last 90 years of automobiles? Do you believe it has accumulated on the edge of the road since 1920 and still there?
Not a lot of UV or oxygen down there, which is why the plankton became oil in the first place. Had all those little dead critters settled into oxidizing water + sediment rather than reducing, they would have simply decomposed.
Those specialized microbes to which William refers are bred for speed of oil eating rather than the mere ability. When cleaning up a spill, speed is what they want.
Stuart Google "Drip-it". It is a funnel with clamps above and below. One clamp goes on the container to save the liquid and the other clamp goes on the container you want to drain. I got one for my wife and she uses it for lotion, shampoo etc. I have one in the shop for glue bottles. We also have one in the kitchen for liquids. My wife liked it so well I ordered more to give as gifts.
Anything water dispersible or water soluble can simply be diluted with water to get the last molecules out of the bottle without the need for a drainage device. Frugality is enhanced for there is no purchase involved. Works especially well for shampoo, GoJo, etc.
Having sold lumber for some years I have come to believe that woodworkers set the bar for frugality. Bass fishers think nothing of spending tens of thousands on a boat and truck to pull it, 10 grand is an impulse purchase for a 4-wheeler for deer hunting, a golf trip is just a weekend vacation. Woodworkers will save a 30 cent scrap of walnut in the hope of using it someday.
Yes, I consider the drastic difference between the environments of surface dwelling aerobic microbes that break it down and deep anaerobic microbes that made the petroleum. But that doesn't make the petroleum distillates in the soil harmless, much less immediately rendered harmless.
I know the oil doesn't stay beside the road for twenty years. In the first heavy rain, it is washed off into rivers, etc., or down into the aquifer. I used to ride a motorcycle when I lived in Florida. I learned the hard way not to take it out right after the first rain following a long dry spell, but to wait until the oil had been washed off the roads.
Even in my little rural community, historically there have been at least three gas stations with buried tanks, about 400, 600 and 1400 ft. respectively from my shallow well that supplies us with drinking water.
closed the shallow part of the Cohansey aquifer. Used to live in Lakewood with a driven 25' deep well and a septic tank. That was 40 years ago, of course, and last I heard they'd all been closed out.
The topic was whether 2.5 ounces (recycled thinner motor oil)vs 2 ounces (regular bar oil) of oil deposited on sawdust now and then while cutting firewood in one of our 50 acres forests is a problem. I think not. And my practices are not going to altered by data on buried petroleum reserves, motorcycle riding or buried gas station tanks which I consider irrelevant to the topic at hand- bar oil.
is reducing the amount of toxics we ask our planet to absorb and still allow us as a species to exist. Your 2.5 ounces are, by themselves, meaningless, but repeated a hundred million times by your neighbors, spells catastrophic oil spill.
The "it's only 2 ounces" attitude is what our parents and fore-bearers used to justify their use of the atmosphere, the land, and the water as their toilets.
Don't tell that to the kids in Flint.
Every one of us can do a little bit every day to either make things better or not make them worse. Preferably both.
First 100' of well casing sealed to prevent draw from that level of the water table. Up here we can get water, I think, at about 75' but it won't pass potability. My well is at 360'.
