REAL MILK PAINT
Rockwell 11-280 32" Radial Drill Press
ChuckInND
Well I got myself into it again. My addiction to old machinery just keeps on a going. I picked up the drill press locally at what I thought was a pretty good deal, but I'll see how it goes. It's going to take some work. The base and table surfaces are rusted, but I'm thinking that tapping off the painted areas real well and sand blasting it may be the answer to that. Then there is a problem of getting the horizontal assembly off of the vertical post, it won't budge. So maybe some heat and then oil it good hopefully will take care of it. That will just be the start of it I'm sure. I'd like to go over the whole machine thoroughly to get it into good working condition. The motor seems pretty week, but I don't know if its the bearings in the motor, or the motor is underpowered, there is no label on the motor to say what it is. And or the bearings in the spindle of the machine are gummed up. It's looking like it will be an adventure, hopefully it will be worth all the effort.
Re: Rockwell 11-280 32" Radial Drill Press
Dave Nichols
I had one and if I remember the motor was either 1/3 or 1/2 horsepower. I had sold it to a friend when I got divorced but bought it back later. While in his care it was stored in a garage with a dirt floor and picked up some rust, I cleaned it off used wd40 and scotch brite pads. It's still going strong in my son's workshop. It was underpowered, I had to take very light cuts when using a fly cutter on it.
ChuckInND
Dave, they had three motor options for the machine. 1/3 hp and 1/2 hp. One of those sizes you could choose a motor with ball bearings, or a motor with sleeves. When we turned this one on at the sellers place, it started fine, but started bogging down, that was without drilling anything. I have a Dayton 1/3 hp, 1750 rpm sleeved motor that is in nice condition that I will try after getting it all cleaned up. Ofcourse I wish that it was a 1/2 hp motor with ball bearings.
Be Careful
applying heat to an iron casting. Should be applied to evenly heat the piece and avoid setting up uneven expansion of the metal. Not hard to crack cast iron that way, and then you have an anchor.
Re: Thank you Mark
ChuckInND
The thought had occurred to me, but now you have reinforced that concern about heating it. Maybe I'll just try soaking with some type of oil such as WD40 like Dave mentioned.
Grant in Iowa
Chuck,
for getting the parts unstuck, I suggest simply soaking them with lube of some sort. It may take a LONG time. Old timers I know who work on old hit and miss engines often use Automatic Transmission Fluid, or diesel. I would propose diesel because it is thinner.
Some swear by PB Blaster, some say WD-40. I think patience is more important than the lube.
FWIW,
Grant in Iowa
And I should add...
Grant in Iowa
I have one of the Craftsman knock-off radial arm drill presses and I will say that they add a great deal of flexibility to what can be done. The deep throat allows you to drill accurately on larger workpieces, to drill compound angles without excessive jigging, etc.
If they have a down side it is that they tend to flex a bit more than your average floor standing DP. You get to control how much of the arm protrudes when drilling, so keep it short to minimize flexing. For this reason, I now use a floor standing Delta most of the time. If I made lots of chairs or similar, I'd use the radial arm.
Another thing to think about is the bench it will live on. At issue is how far the motor sticks out the back. Make sure you think through where it will be to ensure you have room to move and use that arm capability.
I wish you well on the project.
Regards,
Grant in Iowa
WD40 is not much of a penetrating oil
Dick Coers
The WD stands for water displacement. It's fine for working off rust, but there are way better choices for penetrating oils for busting rust, and it is definitely not a good lubricant. They are just really good at marketing!
Machinist's Workshop magazine actually tested penetrants for break
out torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix............ 53 pounds
That last one listed is automatic transmission fluid mixed 50/50 with acetone. For taking rust off a table, I first start with a single edge razor blade in a scraper holder. Then WD40 with a maroon Scotchbrite. Harbor Freight sells the blades by the box of 100. Cheap! Sandblasting can be pretty destructive if done with too course of grit and too much pressure. You definitely won't have a flat table after that.
Re: WD40 is not much of a penetrating oil
ChuckInND
Dick, I'm surprised that PB Blaster isn't much better then WD40. I really don't want to mess with transmission fluid, so maybe I'll try the liquid wrench. Thank you for the good info.
Re: And I should add...
ChuckInND
Grant, I'm usually a fairly patient guy and this doesn't have to be done yesterday, so soaking it for several days I don't mind. As far as drill presses go, I have a newer Craftsman floor model in the main shop with a keyless chuck, and I have a newer model Delta bench top in my smaller basement shop that I use in the winter. Like I said, it's an addiction. I seen the bench top radial drill press locally online for what I thought was a good price and decided that I wanted it. Where I'm going to put it I 'm not sure. Or I may sell it and try to make a few bucks if it's worth my time, but if it isn't I'll keep it. Like you say every once in a while it nice to have something that will drill deeper from the edge. I found out why the motor was slowing down. The rubber motor mounts are all messed up and destroyed, and rubbing against the spinning shaft of the motor. But thats ok, the other motor that I have is a lot newer, in much better condition, and doesn't weigh nearly as much. With the old motor when it is all the way back, it weighs so much that it tips the press over backwards. If I keep the press I will probably bolt it to a metal machinery stand so tipping probably wouldn't be a big issue, but the old motor I have no idea what it is because the label is missing, and it looks ancient.
In my absent minded often confused state, I used brake fluid instead of ATF. Soaked a frozen bolt over night and took it off with my fingers. Have no idea what either one of them is or if one is safer than the other, but bake fluid has worked for me several times.
Re: Sandblasting
ChuckInND
Dick, the milled surfaces don't appear to be pitted. I took some steel wool to them and it cleaned up quite a bit, but I'd like to get it better. I shouldn't have to blast it a lot, and what I'm currently using in the blasting cabinet is glass beads or silica sand so it shouldn't be overly abrasive. It looks to me like this machine sat for awhile in a barn or shed that had a wood floor I'm guessing because there was some dirt on the belt cover and various locations. On another note I noticed that the V-belt is the original Rockwell V-belt, but I'll probably replace it with a link belt.
Re: ATF or Brake Fluid
ChuckInND
Barry I need to loosen up where the horizontal tube goes into the T shaped painted casting. I'm just afraid that ATF or brake fluid would be hard on the paint. I'd rather not remove any paint. But thanks for your input.
Bruce, a MN Galoot
Brake fluid will most assuredly remove paint. At least it did on my motorcycle when the brake master cylinder leaked all over my fairing.
ChuckInND
As I said before, I got myself into it again, this time is proving to be a real challenge. The collar, threaded rod and stop nuts are missing for the depth stop, so I left a message with the seller to see if he has it laying around somewhere. And I can't get the head of the drill press to swivel like it should for angled drilling, or get the horizontal pipe to go in and out which brings the head in or out from the column. I looked at the schematic and there are some wedges and a spring in there I believe for both operations that I'm having a hard time with. This whole project will remind me the next time, if there is one after this to thoroughly check out a used machine a lot better before buying it. I should of known better.
ChuckInND
This morning I found and bought a used tall metal stand much like they sell for bench top drill presses. I'm starting to lean more towards keeping the drill press now. With all the time I have into it, I probably wouldn't come out very well by selling it even though the imported ones of that size without the stand are about $325.
ChuckInND
I've heard the downside before, and structurally I can't imagine it flexing. I would think that it would take an awful lot to flex that pipe any. I doubt that there is much slop in the fittings either. But to tension the stock belt you have to pull the head of the drill press back about an inch from being fully seated, perhaps thats some of the movement issue ? I may try seating it all the way, or maybe an 1/8" short, and size a link belt to it.
Robin Corell
One of the really nice features of a radial drill press is the ability to very easily pivot the head to the edge of the table or past so you can drill things that don't fit on the table. The ends of chair legs are an example. I have a large angle block I clamp to the edge of the table which then gives me a perpendicular surface to clamp the work to.
ChuckInND
Robin, I like the drill press. I'm still spending time on fixing it up. Last night I figured out how I'm going to do a power switch for it, Im going to mount the switch to the machine stand. I also ordered a depth stop collar and rod for it, but no stop nuts. I looked those up this afternoon and am leaning towards a quick release stop nut, but first I have to wait until the rod gets here so I can find out what size and thread count it is. The only problem I'm having a hard time with is, where am I going to put it ? because I really would like to keep it.
Stop nuts...
John in NM
I had the same problem on my older Rockwell regular drill press. The rod was a fine pitch acme, so no taps available. Ended up making a cutter for inside threading on this boat anchor of a lathe we had at work - couldn't cut them with the lathe running, but it worked fine turning the chuck by hand.
I remember seeing lots of those rods available on ebay, about half the time without the nuts. What is it that made people loose them I wonder? Its not like the drill press goes any deeper without them, at least not on any I've seen.
Re: Stop nuts...
ChuckInND
John, that looks good, nice job. And I can understand why you did it, the price of some of the drill press depth stop nuts is hard to understand.
Robin Corell
Ha ha, Can't help you on where to put it. I have a very small shop with a crazy amount of heavy arn strategically placed. When I decided I wanted to get a radial drill press I knew it meant getting rid of my other press at a loss. I decided I wanted a Walker Turner ram head, essentially a radisl arm saw with the saw replaced with a drill press head. I lucked out and stumbled on a Delta Unidrill, a model I had never heard of. I was lucky to find one with the legs and table and on this model the legs weigh 90 lbs and the table weighs 150lbs. the table is 24"x24" with a bump out on the back edge for the column. an arm mounts on the column and the arm has a second smaller column on the end of it that the drill head is mounted on. This puts the motor in front of the main Column so I can place the press against a wall, something that can't be done with a ram head. the heavy weight of the legs and table makes it possible to pivot the arm and head 90° to the side and use the table as my welding table for TIG work.
Perhaps you could modify your press to do double duty or serve as some other function to earn it's keep and justify ours shop space. I once modified a small bench top drill press to use as a horizontal boring machine when I had a recurring job that I did which was much easier done that way. Having other drill presses to use for drilling allows you to only use this one for a specific task and perhaps aa small work table for something else the rest of the time.
Thanks Chuck
John in NM
It was actually a pretty fun little project. The only thing I would change would be to make them out of steel, but I'd never have gotten away with cutting the threads by hand turning the chuck.
Re: John Another idea for a stop nut
ChuckInND
John, I stumbled on a guy who also made his own stop nuts in a way that I've never seen before. http://www.practicalmachinist.com/vb/general/building-better-drill-press-depth-stop-138199/
That is pretty neat...
John in NM
Clever how it locks the threaded one without being fussy to lock, I like it.
