My mid 1980s Unisaw was having binding issues when I tried to adjust blade angle/elevation. So, I assumed , I had sawdust packed into the adjusting threads or a wood sliver that was wedged somehow.
Turns out that the "engineers" that designed this venerable tool made little to no provision for keeping the wiring away from the moving internals of that saw (nothing near the blade at least).
Some plastic ties will hopefully keep me going.....but, I continue to be amazed and disappointed by things that are supposed to be well thought out.
Having worked on a couple of those saws, I remember that the wiring went through several clamps held to the wall of the cabinet to keep the wire away from the trunions and the tilt gear. If you've got a loose or "undressed" wire flopping around, it may have come loose from the fixing. Check your dust bin to see if you've got a stray piece of metal bracket in there.
My saw came with no such bracket.....just as it is.....I bought it new.....and had attempted to eliminate this issue before......hopefully, with more success this time.....just wish these things were done by the manufacturer.
One the "new" one I helped set up and tune, the wire went from the external switch through the cab wall in a grommet, then took a right angle turn alone the cabinet through 2 clamps and then down to the motor. The other was a 40's machine that we upgraded with a 3hp motor and such so I had to dress the wires myself to hold them out of the way.
Are there two open screw holes along the top of your cabinet on the side where the motor wire comes in from the switch? Maybe somebody left out a part.
Somebody also left out the holes.....no holes.....they just plain did not worry about the wires being hooked by the motor.
I become very frustrated by this sort of thing.....when you think about all the technical info that people undergo to get a BA, Masters, or PhD.....and do not have the "common sense" to keep the wiring safe and secure.
I'm not in a good humor right now......took a little while to figure out what my issues were and a while to "fix" them.....and a Unisaw is not particularly friendly to getting your hands, tools, and arms into some of those spaces required.
Beside getting to feel better via ranting.....I'd advise, if you're having similar problems, look to be sure the wiring isn't somehow involved.....don't assume that the tool makers have enough sense to design for your tool's wiring safely.
" You know, it costs money to drill holes and put in those little wire clips. After a few thousand saws, that can mount up. Let's just leave them out."
Clients get the lecture of cost/benefit analysis with the quiz based on one-step forward-two-back. They can pour money down a dry hole or drill a new well in a better location.
