Triton track saw
Joe shelton
Is the Triton track saw at least roughly comparable to the Festool?
I'm not sure I even need one, but the price difference looks very appealing.
Triton track saw
Joe shelton
Re: Triton track saw
Jesse Cloud
If you can do a little hands on with one, the main quality factor is the fit between the raised part of the rail and the groove in the bed of the bottom of the saw. If there is any slop, and no way to adjust it, its useless. If you can adjust, try to get it to a point where it moves smoothly, but there is no slop. If you can't, its not worth any price.
The other thing is the variety of lengths of track they sell and/or the ability to connect multiple tracks in a truly straight line. One short track will work for cross-cutting sheet goods, but won't do long cuts.
I am puzzled by Triton. I have bought some really good products from them and some that were crap. Hope the track saw is one of the good ones!
Dick Coers
I've not used one but read a review after you asked. It was the heaviest one tested, the author didn't like the reverse direction limiter that prevented kickback, but the quick setting to make a scoring cut sure looked like a great feature. The 55 Festool was the winner in that review, and Makita was the best value.
james runchey
I don't quite follow the attraction of having a dedicated tracksaw. I've obtainted perfect results with a homemade guide made of 2 pieces of plywood using the factory edge as a guide. I've cut up a lot of sheet goods using this. What am I missing?
Dick Coers
You don't need any clamps with the track saw, the foam on the back of the track grips really well. You get an adjustable fit on a raised area of the track, so you don't have to concentrate the hand effort to keep the saw against a fence. Need to reset your grip? Just let it come out of the wood, let the saw stop, move around, and then start is back up, plunge and continue to cut. No letting the saw die in the cut. You also get a plunge saw, so inside cuts are easier. Maybe if my circular saw was better quality, I wouldn't be so impressed with the quality of the bearings and quality of cut with these high end saws. Depth stops and set up are so easy with accurate scales on the saw. That's my take. I worked off 2 layered plywood fences for decades, track saws are easier!
fred in ct
I second everything Dick said plus with the Festool there is a zero clearance which gives a perfect cut with no tear out.
