I need display cabinet (China Cabinet) inspiration
We need something to display the family heirlooms- cut glass bowls and the like. I am imagining something 5' high by 30" wide more or less. Making it from rift cut ash with simple lines would be appropriate for where it goes.
There aren't a lot of this sort of thing made to find and look at for inspiration. I guess the modern family doesn't have either the space or heirlooms for when I search pictures I find ornate affairs from 1920.
Krenov made lots of tiny wall units but they don't scale well to a floor model.
If anyone has a picture of a modern looking floor model display case with simple lines please post a picture. Where do I find how to do the joinery for a large glass door?
Re: I need display cabinet (China Cabinet) inspiration
Here's one
Craig Thibodeau
Bill, here's one I did a few years ago in Cherry and Koa. It's a bit taller than 5' but maybe there is something you can pull from it. It's got a slight bow in the front of the cabinet including the upper portion but the glass in the upper doors is flat.
I use mortise and tenon joinery in my glass doors and they are plenty strong. If the glass is heavy, 1/4" rather than 1/8", it might not be a bad idea to have the door rest on a small block when closed to reduce the potential for sagging. I've used hardwood dowels drilled into a hole under the door in its closed position.
Craig
I built one like that once
Sorry, no pics, but here's a one-minute sketch of the piece from memory. This particular cabinet was made of solid West Indian satinwood, with two wide-board vertical panels set in a frame for the back. I installed three puck lights in the center of the "ceiling" of the piece. The shelves were 1/4" polished-edge float glass. The knobs were turned ivory. The edges of the doors were rabbeted where they meet in the middle.
Krenov Made nice box-on-stand pieces that would lend to china cabinets.
Gorgeous, Craig
That looks like it could have been made by JK himself! Wonderful work!
Alan Young
Working on this one right now
Alan Young
Client has a stained glass window they wanted used in a media cabinet-It will look like this---Of course you could use transparent glass-or leave the top open
The stained glass door is 9 pounds I made the frame for it with loose tenon joinery-No worries.
Very nice!
John in NM
Bet that would look good in rift sawn ash too! :D
Thanks Ellis
Craig Thibodeau
It does seem pretty close to Krenovs style doesn't it, he was a big influence in my early years, wish I would have had a chance to study with him. This piece was part of a complete dining room set for a very good client.
On another note it's been a long time since I posted anything on Woodcentral and it's nice to be back in some form, still seems like the only good forum out there in my opinion.
Craig
engineering question
The pictures have been inspirational.
I am at a fork in the road on design with a pot hole in one fork that I don't know how to overcome.
One possible approach is a cabinet based on 4 posts that would go to the floor as crudely illustrated in the picture. This design would be light and airy. The door and side glass would go between the posts in some way as yet to be determined. The stumbling block is how would one put a floor in this arrangement? I suppose it could be tediously fit around the posts and join the side rails somehow. I can't imagine being able to do it without gaps somewhere.
If all you need for now *LINK*
Gary Smyth
are ideas and photos, go to "pinterest" on any browser. On the search line type in "display cabinets". There will appear hundreds of photos (no plans). There are tabs on the top you can select "Glass", "Oak", "Built-in", "Modern", etc. From there if you select a photo, typically a page/site selection will be available for that selected cabinet. Mostly that will be a place to purchase though.
Should that not work, try "china cabinets" to get a similar but different result.
If you want to narrow further, type in a descriptive term and follow with "cabinet" and a tighter selection will appear.
Pinterest is just for ideas and usually only one view, but it's a start.
http://www.pinterest.com
Alan Young
Case on Base ???
Alan Young
Bill- How about this concept?--- two separate pieces with the floor as part of the base--
I did something like that in this piece
Re: Case on Base ???
That is the only way I have thunk my way out of adding a floor to a post arrangement. My other fork in the road leads to more conventional cabinet framing where the cabinet sits on some sort of bracket foot base. The latter will be much easier to engineer and execute. But I think posts that go to the floor or appear to go to the floor would look more interesting.
I need to ask Craig how he got a floor in his piece.
Change the posts
John in NM
Instead of solid posts use 4/4 stock to make L shaped posts. Inside is then a simple rectangle or square.
That's it
What I sketched last night is similar to the top of this piece, except I had not settled on the top, and most lacking, I had not figured out how to set in on the floor and add a bottom to the display area. I won't use the top in the picture but I don't know what I will use. But I wanted to do the doors like in the picture. "All that remained was to figure out what to mount the doors into :) I don't know how I arrived at the door design. Maybe saw it at Fort Bragg or some Gallery....who knows.
Is this something you made? I like it except I need something where the display area goes to the floor.
Question
That is a delightful piece. It is simply pleasant to look at.
Can you provide details of how the floor in the bottom part is installed?
I have imagined a long sweep as you have for the top molding for past pieces but didn't know how to make it. How is something like this profile done?
Re: That's it
jcousins
it is a piece i made a few years back. are you looking to add more display capacity in the lower section?
jerry
Alan Young
I agree-
Alan Young
I use this for much of my cabinet framing - You can glue cleats to the inside and set the floor
on the cleats- level with the opening or lower if you want a lip....
That is REALLY nice!
Bruce, a MN Galoot
How is anigre to work? I've been looking for inspiration for a cabinet to display some precious keepsakes I have and this is the best I've seen. Are the shelves tempered or isn't that necessary?
Clint Searl
Take your pick
Clint Searl
Re: That is REALLY nice!
jcousins
anigre is nice to work - but it is a bit like teak - pretty gritty and takes the edge of tools readily.
much anigre is flat-sawn - i had to keep looking for 1/4 sawn stock
the shelves are tempered with the edges polished
thanks, jerry
answer and a question
"are you looking to add more display capacity in the lower section?
jerry "
yes. My vision is glass to near the floor- no drawers but legs of some sort
Lovely piece. How is the top section attached to the bottom section?
I think it would work to do a top section similar to yours and then just set it on a short base section like a short "table" with arched skirt.
Re: answer and a question
jcousins
top just sits on the bottom - snugged into surround moldings - made it easier to transport as 2 pieces. it is stout enough that i did not feel a need to actually fasten it.
jerry
Re: Question
Craig Thibodeau
Hi Bill,
The bottom cabinet is assembled in a particular way. I tend to do most of my glueups this way:
-The panel for the bottom has both from and rear stretchers glued to it.
-Then the back panel is glued to the bottom panel.
-The side panels have the bottom stretchers glued to them
-Then the legs are glued to the side panels.
-The completed side panels are then glued to the bottom/back panel combo.
Hopefully that all makes sense. I wrote an article for Fine Woodworking last year (issue 247) describing the exact process along with the joinery I use. There was a second part that covered the veneering process in an earlier issue (234 I believe).
As for the top overhang, I rough cut the angle on the tablesaw and then use handplanes to shape the curve until it is very close to the correct shape. After that a bit of sandpaper to fair things in and it's done. I do tend to add a scrap piece to the front and back so the ends don't blow out when planing. Those then get cut off on the bandsaw and the front and back edges get smoothed.
Craig
