Lathe noise
Lathe noise
Lathe noise
CJ in MPLS
I just bought a new to me (likely older that I) Delta Rockwell Wood Lathe 46-200. The lathe appears to work quite well, but it has one problem in that the original sheet metal stand/cabinet rattles loudly during operation. When I reassemble the lathe I will be using a bit of gasket material between the panels and this, along with a thorough tightening of all the bolts will hopefully reduce the noise a bit. Any other recommendations on reducing the rattle?
CJ
Re: Lathe noise
Re: Lathe noise
roger lance
I wedged a rubber door stop under the motor mount and the base of the cabinet which worked to reduce the noise considerably.....by no means completely.
Re: Lathe noise
Re: Lathe noise
Matt W
I built a shelf at the bottom of my lathe stand and set two large concrete blocks on it. This goes a long way to dampen vibration and provide overall stability to the entire unit.
Re: Lathe noise
Re: Lathe noise
CJ in MPLS
I was looking about and noticed a significant amount of wobble in the drive sheave so I am going to guess that that is where most of the wobble is coming from. I'll try to get that off of there to see if the motor shaft is bent or if I merely need to adjust the sheave itself. The bent shaft would be too bad as otherwise the motor appears to be working well.
Re: Lathe noise
Re: Lathe noise
Bruce, a MN Galoot
I did exactly the same thing with both my belt grinders, effectively taking the weight off the motor and belt. It helped tremendously reduce both vibration and noise.
Re: Lathe noise
Re: Lathe noise
CJ in MPLS
So in the end, it would appear that I simply needed to check the sheave and properly tension the belt. The new lathe is a great addition.
A nice fellow in Woodbury is being transferred by 3M and is selling all of his stationary tools. I got the lathe and a Powermatic 30B disc/belt sander for $950. So while I hurt in far too many places from moving this stuff, I have a very self satisfied smile just now. ;)
Re: Lathe noise
Re: Lathe noise
Barry L Elder
A lot of good suggestions for you to follow up on! :D
Re: Lathe noise
Re: Lathe noise
Bill White
I used clear silicone caulk on the panels for my lathe. Even though the panels were tightened properly there were still some harmonics causing a rattle. The caulk solved the buzzing.
Bill
Re: Lathe noise
Re: Lathe noise
Dick Coers
You could press a piece of OSB into the wet silicone, or use construction adhesive to glue sheet goods to the sheet metal to change the harmonics.
Re: Lathe noise
Re: Lathe noise
Bruce, a MN Galoot
You dawg! I guess I should follow CL more closely.
Re: Lathe noise
Re: Lathe noise
TomD
While getting to the bottom of it is worthwhile, also consider that you can't hear most lathes over the cutting tool noise.
If the panels still make noise regardless of what you did with the joints, a simple fix is to add some limb savers. They make a range of products that kill vibe. feel around until you are not at a node, and slap on on.
Re: Lathe noise
Re: Lathe noise
CJ in MPLS
I think that the main issue related to the slightly misaligned sheave and to the fact that the belt was not properly tensioned. The motor provides the belt tension and in the setting it was in the vibrating sheave bounced the motor off of the back of the sheet metal. We are back into the realm of standard lathe noise I'd say.
Thanks,
CJ
