My new shop (Pic intensive)
mdclor
Starting in July I began asking a few questions relative to a new shop I built in half of the basement on the house we moved into in June. Thank you to everyone for their suggestions and guidance.
The overall space is 57' x 19' x 8' and is divided up by load bearing walls. Therefore, I have rooms that aren't sized the way I would have made them if I were working with a blank slate. The main room is a little tight in a few areas and the finishing room is a little cramped while I have way too much space for the dust collector, the compressor and wood storage. Overall, I am very happy with the space.
I am not quite done with everything and I will probably move some of the larger tools around a bit, but it is close to being what it will be. I think the workflow will be okay and that is the main consideration.
Here are the pix:
Thanks for looking.
Re: My new shop (Pic intensive)
Pete in Holland MI
Very cool.
Picture #12: What's the black piping darting back & forth on the back wall ?
Pete
Betcha
it's Merl's attempt at a water vapor condenser for his air line that comes through the wall from the next room where his compressor is located.
air line condenser?
That's what I figured. I read the water collector/drier should be at least 25ft from the compressor to let the air cool. I plan to run a loop around the inside of my compressor closet near the ceiling, sloped to let any water run down to a catch tube with drain.
mdclor
Pete, thank you. Mark and John are correct. I have a little over 40 feet of black pipe before the filter. It slopes at about 1/8" per foot.
AZ in Colorado Springs
That's a nice adventure, setting up a new shop. I bet a year from now you'll have found some ideas to optimize the odd spaces you have to work with. And that's more of the adventure.
Condenser
If you want better drying do 2 things:
1. Run a 60 pint dehumidifier in your compressor room set at 30% and drain it outside with a Little Giant pump with a check valve. This will control the amount of water vapor you comp sucks in.
2. Swap out that black pipe for 1/2" copper as it is far more heat-conductive than steel and will never rust.
Congratulations. I remember the first days after I built my workshop. They were the last days that place was ever clean! I have always felt that the most important thing in my shop was actually the space to work in. Enjoy yours!
T.
Looking great Merle
John in NM
Very bright, and far roomier than I expected from your descriptions and previous pictures :D
Outstanding!
Don Orr
I hope it provides you many years of happy woodworking. Enjoy.
Jesse Cloud
Awesome shop!
I remember when we crated up the old one and I am very pleased to see that it survived the trip and is thriving in its new home.
Can hardly wait to see pics of your new-shop-made vanities finished and installed!
Your pics inspire me to set aside some serious time to clean and organize my messy, cramped shop.
Re: Condenser
mdclor
Mark, thanks for the tip, but I have enough other projects on my list right now to keep me busy for the foreseeable future. Maybe someday... :)
mdclor
Andrew, shops tend to evolve with changing needs. I have already begun taking baby steps toward getting friendlier with my hand tools so maybe I will need a super sharpening station at some point. ;) Now, I know just where to put it.
mdclor
Thanks, Thomas, I will. :)
Re: Looking great Merle
mdclor
John, it looks brighter because of all the LED lights and the white paint. haha I have described it as cramped because I had so much room in NM that this is small by comparison, but I know that it is huge compared to what many people have. Also, I could have made my out feed/assembly table smaller then 4' x 8'.....
Re: Outstanding!
mdclor
Thanks, Don, it will be my last shop so I did as much as I could. Of course, I have built my "last" shop twice before. :D
mdclor
Thank you, Jess, both for the kind words and the help crating all the tools, etc. Your shop is only cramped because you own at least one of every Festool product ever made. haha Just kidding! Anyhow, you could easily add 10' to the north end and increase your space by 50%. Let me know when you need a hand, I can stay with my sister during construction.
Re: Condenser
A basement shop will NEED a good dehumidifier running to control the humidity. My office and my shop are located in my basement and we have 2 60-pint units running from March 1 through mid-November. The shop unit continually drains to the A/C condensate pump and the office machine has to be emptied twice a day (good source of water for house plants)
Re: Condenser
mdclor
Mark, I survived this past summer with just the AC running. There are vents and returns in the basement. IIRC the humidity stayed about 70% and the temperature was cooler than the main part of the house because the shop is mostly below ground level. I will have to pay attention to it next year.
Hank Knight
Nice! You spent some time and thought on the DC and air plumbing. They both look great. I envy your space. My shop is a basement shop, but it's only about half the size of yours. I have enjoyed being in the basemant as opposed to my old detached garage. The basement is much more convenient. Enjoy your shop. T looks like you're well set up.
mdclor
Thank you, Hank! I once had a shop in an unheated, detached garage and it was a pain. The air conditioned basement is much more convenient.
Re: Condenser
Ron in Sterling, CT
My shop is in the basement, and I run a dehumidifier April through mid November. I keep the RH at between 60 and 65, and do not have any rust problems. In my experience 70% RH is getting close to where tools will start light rusting. My 2 cents.
Ron
Re: Condenser
mdclor
Thanks, Ron, I will watch for that next summer. Actually, I am keeping a log now with the humidity and temperature on an almost daily basis so I will have a better idea what to expect for wood movement.
Re: Is that an IR T-30 Compressor?
Stephen Roth
I was just thinking about upgrading my pancake compressor to a 60 gal. Ingersoll Rand T-30 type compressor. Yours looks like that. I know this may be overkill in a woodworking shop, but I try to upgrade only once after finding that a certain tool is useful. (I hate buying two lower cost replacements for the same price as the single better tool.) My concern is that the T-30 may be loud in the basement, or take a long time to pressurize on startup if I depressurize the tank after use. Any thoughts on your experience would be helpful.
PS: Nice shop.
I can't see the picture clearly enough, but that looks very much like the I-R compressor I bought for my shop, 60 gal, 5 hp, two-stage compressor.
It is pretty loud but I put it in a sound-insulated closet with my cyclone dust collector and brought the air and controls through the wall so I could access them and have the dryers, regulator, and valves in the main shop.
It might be overkill for a small wood shop but I also use air tools in my vehicle maintenance bay, air up farm equipment tires, spray coolant mist for milling, and use it with a plasma cutter. Even use it occasionally to blow leaves out of the gutters! I plumbed the shop with air outlets all around and outside. It might be big, but it still cycles often enough that I'm glad I didn't get a smaller one.
