DC tripping protected outlet
A.J. Hamler
As I think I've noted prominently before, I don't know nothing about electricity. Well, that's not true -- my grandfather always told me that you shouldn't touch a bare wire while holding an open can of beer, but I've been told by others that holding the open can of beer is irrelevant, that it's the touching-the-bare-wire part that's key. I'm not willing to test that theory, however.
Bottom line, I don't no electrics.
So -- I recently got a PSI Long Ranger remote switch to use with my Jet DC-1100 dust collector. The switch works wonderfully, and I wish I had gotten one a long time ago. I'm having an issue with it, however.
For some reason, the dust collector is now constantly tripping the protected outlet it's plugged into, the kind with the reset button. I've had the collector for a year and it's been plugged into the same outlet it is now, and not once has it tripped the breaker for the circuit itself (it's a 30-amp line). But now that the DC is plugged into the Long Ranger -- which, in turn, is plugged into the same outlet the DC was plugged into before -- it's tripping the outlet a bit more than half the time. Maybe two out of three times it's used.
The tripping occurs not on powering up the DC with the Long Ranger remote, but rather on power-down. The DC fires up just fine and runs fine as long as I need it, but when turning it off as it winds down the outlet trips and must be reset before it's usable again.
I'm embarrassingly clueless. I've sent an email to PSI but haven't heard back yet, and thought I'd see if anyone here had any idea what's up with this, and how I can correct it.
TIA
