I felt I should finish the Game table
Alan Young
This Game Table is set to ship out this week. The Table is made from solid Sapele for the legs, aprons and drawer fronts.
The removable top has a chess/checkerboard veneered in Sapele and Bird's Eye Maple. Finish is toned Shellac.
When the the top is removed a felt covered game surface is revealed for assembling puzzles or playing cards or other games.
The underside of the top is veneered in Sapele with brass squares set in each corner.
The squares sit over the leveling bolts that hold the top over the felt covered game surface.
The drawers are lined in felt. In a post a week or two ago I asked for help in ideas and techniques for applying felt or flocking to the drawers as my previous techniques and efforts were unsatisfactory-I appreciate the suggestions and comments from that post. So on this project I wrapped the felt over 1/8th inch hardboard pieces that were sprayed with adhesive. The covered pieces were then attached to each surface with the same spray adhesive. I am much happier with this technique so thanks to all who added to that thread-here are the drawers---
I made these threaded inserts and these Brass Leveling Pads
A threaded insert is epoxied into the bottom of each leg.
Then a leveling pad is screwed into the insert.
