A perfect resaw. Yeah, right.
Tom Pilsbury (Chicago)
I need a lid for a small box I'm making so I pulled this nice piece of mahagony out of my stash and set up the bandsaw for a resaw cut.
Wood is approx. 5 1/2" x 10". 1/2" Timberwolf blade
Wow! Look how good it came out. I really impressed myself. I'm getting pretty good at this woodworking stuff.
Yep. Too good to be true. I should have known.
Arrrrrgggh! Biscuits! I didn't realize it was a leftover piece from an edge glued board from a long ago project. It will be inside the box so I guess I can still use it. I'll just call it a "design element". :)
Re: A perfect resaw. Yeah, right.
roger lance
I am impressed with that resaw.....about as good as can be done.....maybe your planer could remove all traces of the biscuits and leave you with enough thickness.
William Duffield
Just one more reason you don't need biscuits for edge joining panels. In this "application" a Domino has zero advantages over a biscuit. DAMHIKT.
Too short for the planer. Manual states "never plane material shorter than 14 inches". I'll hit it with a hand scraper and sandpaper. Maybe that will do it.
In this "application" Both biscuits and Dominoes have a serious advantage over Kreg screws. I guess there is no chance you would have "not seen" the Kreg screws, but if you run your best blade through a biscuit or Domino you get to keep on using the blade. Not so much with a Kreg screw. DAMHIKT
You could glue longer "rails" on the edges of the pieces and run them through the planer. Let them stick out the front and back about three inches and they eliminate snipe on the work piece.
Pretty resaw though.
Blame Norm
When I started out, some 20 years ago, I took Norm's queue to use biscuits to edge glue panels. Somewhere along the way a sage woodworker clued me in to the futility of such practice.
I have butt glued thousands of panels ever since an have never had a joint fail yet. No biscuits necessary!
Sorry about your "discovery".
T.
Time
to learn to inlay dutchmen.
William Duffield
And if you are using a SawStop and hit a Kreg screw, there's a good chance you'll trip the brake, too, for another $80 "Aw, Crud!"
Important Disclosure
David Yoho
No real Dutch men will be harmed in the process ;) ;)
Sorry, couldn't resist!!
must have been a good looking joint
Actually it is perfect...
John in NM
Bet you couldn't do that if you were trying to - I know I couldn't! :D
Those biscuits just serve to display excellent technique, put a frame around it and hang it on the shop wall!
Use a sled...
John in NM
You got two pieces after all :D
Piece of plywood under both with a cleat on the end, or just with some sandpaper glued to the face.
I'd still hang that on the wall though :D
