On hauling sheet goods and a Menard's Rant
Grant in Iowa
My Chevrolet truck, along with all of the full sized trucks, readily receives 4' x 8' sheet stock. If I would have bought the long bed version, it would even accept it with the tailgate up. It even has enough overkill to easily receive MDF with its extra inch.
Long ago I had a '78 El Camino, which would not accept MDF, but would accept normal ply (if memory serves). The factory air shocks meant it could be readily overloaded without looking like it was.
So I wonder if a similar vehicle exists wherever Baltic Birch is the norm.
I used to have an S-10 blazer when I was younger and was pleasantly surprised to learn that a 4x8 sheet of plywood would fit inside diagonally with the tailgate down. The plywood would stop neatly at the tailgate almost like someone planned it that way.
I often wonder how the world would look if the average human was -say 2 or 3' tall. Everything man made would be smaller, except strawberries would seem huge. I'd like that I think. At least until it was time to clean up the dog doo.
Now, on to Menards. Some person who has clearly neither owned a pickup nor ever moved much plywood alone has engineered the plywood aisle at Menard's, probably with the help of an injury lawyer.
So you go to the plywood aisle, and it is filled with A-frame carts. It seems all of the ones that should really be over by the trim, conduit, PVC pipe, etc. have been rounded up by an employee who has been told it is to be so. Never mind that from an ergonomic aspect, the A-frame cart is about impossible to load plywood in to, and even with help it is more work than it need be.
My approach is to go off in search of the elusive flat top cart, push it up to the plywood aisle and move all of the a-frame carts out of my way. Then I can pull out the sheets I need directly on to the flat top cart. Then I can push the flat top cart out to my truck and slide the plywood directly in to the bed. Never had to lift them entirely, never had to rotate, flip, turn, etc. I can even skip the damaged top sheet or two by sliding two out, pushing the top one back, wash rinse repeat. Works great, no need to find a staff member to help.
When told the carts are all wrong for the application, the manager said it is downward directed from corporate for safety of guests. It seems someone was injured by a plywood corner at some point, so the A-frame carts are put "in your face" in the plywood aisle. I asked him the rhetorical question: "How many guests have injured themselves picking up plywood, rotating it, placing it in to an a-frame cart, then repeating the process at their truck?" No answer as expected.
To the positive, if you have a contractors license (easy to get here in Iowa), you can get a "contractors card" allowing you to park in the lumber yard when you arrive. Right near the automatic doors where the plywood and contractors desk is. Saves steps, until you realize you still need to go to the register to check out. At least you don't need to push the cart back and forth.
Ok, I feel better now. Thanks for listening.
Regards,
Grant in Iowa
