Have a question? Ask Woody!
Lag screw lubricant
Lag screw lubricant
Lag screw lubricant
Howardd
I need to drive 3/8 lag bolts about five inches into popler to bolt down a mill drill onto a stand I made. Will be drilling pilot holes. Is there a lubricant I can put on the bolts to reduce friction.
Thanks.
Howard
Re: Lag screw lubricant
John Veerkamp
wax
waroland
Get an Impact Driver.
Tom Dunlap
Dawn dishsoap
Paul Kramer
Paul Kramer
If you're not worried about staining the wood toilet bowl wax is excellent in that it clings to the screw well. I've found that if the screw is warm before touching it to beeswax or paraffin allows the wax to coat the screw better.
HTH,
Paul
Dale Lenz
Second the toilet bowl wax...
Dale Lenz
Have heard that soap over time will attack the metal.
If you have only a few screws to drive and you have an old candle around, yes wax would be my choice.
TomD
With properly sized holes I don't want wax, but you do, so. In such cases epoxy is a possible choice as it is as slick as grease, but hardens off. One could paste wax the screws, and use epoxy as the lube, so as to make them easier to back out. That way you fill in any slop in the holes.
In my case I would probably hardware bond studs, and then use some pretty nuts. Or spares in the hold down kit.
John McGaw
I've found that a waxy concoction I made a few years back as a friction polish for turnings works great. It is basically bees and carnauba wax with a bit of turpentine as a carrier. I suspect that any good paste wax would work as well though. In the past I've used paraffin wax but it is a PITA since it doesn't stay on the threads but bees wax by itself works pretty well. Soap is definitely not a good thing to use.
paul woolson
My dad always had a bar of lifeboy in his screw can. We always just scraped the threads against the soap and it worked very well as a lube. Though it was said above that soap might attack the metal, I've got no knowledge or experience to that.
Bolts?
What size of machine, is the stand mobile or fixed, what material is the top?
Depending on the material, I would make the pilot holes the same size as the solid part of the lag screw and rub a small amount of paraffin or beeswax on the threads if needed.
However, for machinery, assuming you can get to the underside of the table, I really prefer bolts with washers and lock washers (or better, nylon locknuts). This eliminates the problems with some materials like MDF and particle board that may not take the threads gracefully, and issues with lag screws loosening over time as wood expands with moisture and dries and shrinks, especially if there is any vibration from the machine.
If the stand top is made from some kind of manufactured wood product with no access to the underside I might soak the insides of the pilot holes with super glue and let it set up before fastening. I've done this with good results. (I would not glue in the screws which might make snugging up or clean removal difficult.) For MDF and such I would be careful to not make the pilot hole too small. Just my experience.
All this said, your mill drill may not need much to keep it in place (unless it is on a mobile stand.) Before I built a permanent bench for my small milling machine I used it for months with nothing more than a few big sheet metal screws to keep it from falling over if it got bumped.
John in NM
Whatever kind of wax you have on hand. I use furniture wax because I have it already, but if I didn't I would go get a wax ring for a toilet as others suggested. It's cheap, easy and sticky.
If you don't have a cordless impact driver, you might consider buying one. Makes a job like this such a breeze. Only downside is that it'll work so well you might skip the wax (and then torque off a bolt! :D )
don stephan
A few months ago I read that soap is hydroscopic, attracting moisture.
I've used furniture wax, because it is easy to spread, and paraffin when I was worried about furniture wax stains. With longer fasteners I often drive about an inch, withdraw and add more paraffin, and so on - whenever driving gets noticeably more difficult.
Worlds best screw lube
The product is Johnsons stick wax. Machine shops use it to lube band saw blades. It is just the right softenss to easily stick to the screw. Just used some to lag the vise to the Moravian bench.
Not soap
It will enhance corrosion of steel over time.
Bee's wax
Mike Farinella
I use it all the time.
I would drill the holes in two steps. Look at your bolts and drill the first stage the same diameter as the actual bolt and to the depth of the unthreaded part. Then drill the rest of the hole at the root diameter. Then I would use bee's wax, paraffin, or a wax ring (a new one, not a used one). And I would use an impact driver. I have an older Makita and a newer Bosch one. they are both favorite tools and would get replaced in a minute.
Impact Driver
Howardd
It is a 3/8 inch bolt and I'm driving it into 4 inches of popler.
Is the bolt more likely to break if I use a impact driver instead of a socket wrench?
Would stainless steel bolts be stronger?
Thanks
Howard
Are we talking about the same screw!
One puts lags in with a wrench.
Stainless steel is weaker than ordinary steel when it comes to shearing the screw.
I have installed pounds of lags, up to 8" long. Drill the pilot hole the diameter of the bolt minus the threads, lube if going into hardwood (no need in softwood, apply the wrench and go to it. Remember a washer.
Re: Impact Driver
John in NM
You won't break a bolt that big with a cordless impact, the bolt might stall out going in, depending on lube/pilot hole size. I've driven long 1/4" lags with a 3/16" pilot with no trouble (no lube, in spruce/fir).
Biggest advantage of an impact is speed in this case. I wouldn't drive phillips head screws any other way, but for hex head it's just quicker and easy.
I was being a little facetious about breaking a lag screw earlier, you might be able to break a long 1/4" one but I doubt an impact could do that even. Most I've ever broken with one was a driver I made up for "tapping" holes for threaded inserts in resin treated burl. Old insert welded to a spare 1/4" hex bit. Always broke at the weld (not surprising really).
Yep, you can break 'em
Henry Higginbotham
I recently had occasion to run about 70-80 1/4" lag screws, some 5" and some 6", into some creosoted timbers that had spent about 30 years as part of a guardrail, so the wood was less than solid throughout. The heads snapped off of 5 or 6, even though I had drilled pilot holes (but without lubrication). Bosch 14.4V impact.
Re: Are we talking about the same screw!
Grant in Iowa
I have broken 3/8" hot dipped galvanized lag screws with an 18V DeWalt impact driver. The incident I am thinking of was while mounting a ledger board for a deck build. The ledger was drilled clearance size, and the un-drilled rim joist was 1970's KD SPF 2x10.
When the first one broke, I recall thinking "I can't believe the 1/4" to 3/8" socket adapter didn't break first". Then I decided it was a defective bolt, so I tried another and broke it. My suspicion is that the rim joist had dried and was therefore quite hard. The issue was resolved by drilling a pilot hole in the rim joist. Shouldn't have had to, because it was a soft wood, but needed to because it was likely very dry.
Point being, they can be sheared off with the tool, and today's impact drivers pack more and more punch with each generation. 1400+ inch pounds in the modern Li-Ion 20V impact drivers with the 1/4' bit, and more yet if you buy an impact wrench with the 1/2" drive.
FWIW,
Grant in Iowa
getting back t the task at hand.....
I would suppose we are talking about 4 or 6 lags, to hold down this machine. This task hardly seem onerous to tackle with a ratchet wrench, my weapon of choice for lags. Using the wrench one can estimate the torque and drill a bigger hole if the force to drive the lag gets too great.
The only ones I have ever broken were being taken out of some assembly where they had rusted in place.
Bill, Bill, Bill ..... the hammer is for putting them in, the wrench is for taking them out.....
If you have not driven lag bolts with an impact driver, you have missed all the fun. My little 12 volt ones are under powered compared to the newer higher voltage ones, but I drill a short clearance hole for the shank and then a pilot hole for the threads and have at it. I have not lubed one in a long time, but it might help. Try it, you will like it. Hard to beat for deck building. I even use it for tightening the nuts on bolts. You won't remember where you laid the wrench down.
To the OP, Why such long bolts? I would think 3" lags would develop plenty of withdrawal resistance.
TomD
"To the OP, Why such long bolts? I would think 3" lags would develop plenty of withdrawal resistance."
Not to mention the weight of the machine. One of my lathes was held in with deck screws.
I like to use a hand-operated socket wrench for lag screws, at least for the last bit of tighting. I want to be able to judge by feel the amount of force applied.
I have watched people break and distort things with "tighter is better." Over the years I have broken and warped things myself learning how much is too much.
