Magnetic Jointer blade setting jig
Scott Burr in Ben Lomond CA
Hi All,
I'm finishing up restoring a circa 1940's-50's Delta 6" short bed jointer.
Any recommendations for a blade setting jig?
It's need to be magnetic because it has no spring or other blade adjustments.
Thanks!
Re: Magnetic Jointer blade setting jig
TomD
I set my general jointer using two strong tool holding bars. Now that on can get rare earth magnets cheaply, all one needs is a couple of wood or aluminum sections that can hold magnets. Put a witness mark so the blades are hanging from the same position in turn, and you are ready to go. Lee valley sells cups that are designed to hold magnets in surface mounts for even simpler instalation. The accuracy of the magnets is not critical except that they are all co planer, and the blades are hanging from the same position on each when you start to tighten the screws.
All this assumes that your outfeed table is adjustable so that the final height of the blades is easily adjusted just so long as the blades are at the same height.
The style I bought for the tool holders were designed to hold turning tools, where the bowl gouges can be heavy and have minimal contact area with the bars, something of this type.
http://www.highlandwoodworking.com/heavydutymagnetictoolholder24.aspx
Or make your own:
http://www.leevalley.com/en/wood/page.aspx?p=58750&cat=1,42363,42348
Later I found the jointer and planer setters on sale and bought those, but the jointer set is no better than my unit and was actually a little lightweight for some of the larger machines. None of planers have needed mag setters, so I haven't had cause to use those.
I would also say that in a world of 5 dollar dial indicators, it is no biggie to set the blades with one of those. It seemed like one of thos ebig mysteries when I read an article, or really just something I didn't have the gear for at the time, but in reality it is a bog standard set up process for any machinist, something one would do over and over. What made some of the articles scary was the folks had modified their machines with drilled holes to make repeatable settings easier to get, and that is just not necesarry a few scaps of this an that and you can set your knives easily. For a home shop, one does not do it all that often, so why spend the time to machine the machine, but for a pro shop I could see it.
All you really need for a set-up is two dial indicator holders, something clamped or magnetic to hold the blades in the same relative rotation. So if you clamped or magneted a board to a scribe line on the table, and had a second board that when dropped into place would establish the rotation off the back of the blade slot, you have your rotation set. There are cheap ways of doing that with cheap lasers (4 bucks). Then you mount your blades high, and tap them down into position with a soft hammer, until they read the same on the dials.
Finally there is the drag forward method that just requires a flat piece of wood. You eyeball an initial position relative to the outfeed, when you rotate the stick you use that to measure the lifted up and set down position as the stick is carried from around 11 to 1 o'clock. Same distance same height. If you have a dial you can use that to check. The advantage to this system is that it is does not require a means of measuring height, rotational position, or fixing the rotational position.
Matt Robinette
I have used a set of Planer Pals when I had a Jet 6 inch jointer. They worked great.
Wow, thanks Tom. What great info, seeing how I have the magnetic bars already I'll go with this approach. I don't even have to buy anything!
Thanks again,
Scott
