Re: Joinery Question
TomD
Sheet goods probably, but I would rather do something interesting than all that banding. FOr solid wood:
First blush if you look at the left side of the wall there are 2 C shaped 3 sided boxes, I would make those with fixed and glued biscuit butt joints, such that there is no cross grain, end grain ends to ends, but just butt and biscuit, or some similar joint. I don't think dovetails really work in this situation as it currently stands.
You then mount these boxes in place on the wall (or hold that as a thought). The bottom of this run is a half box, just treat it as a full box if you like and mount it with the others.
Then on the right side you have a half panel on top and two full panels, these present your cross grain situation, You can simply tack them to the wall like cleats, and leave it like that, another option is to use biscuits or splines, and glue one biscuit, or end and either slide them in place, or glue them up.
You can actually get rid of the cross grain issue, by making all the right side pieces so the grain runs from the corner out, and all the left side pieces into end to end boxes (as suggested above), so that where they contact the right hand pieces it is side grain. Then you get a vertical expansion issue, but that probably isn't all that serious, and could be dealt with in the mounting (keyhole them). The only problem in that approach is that when removed from the wall the unit might be a little fragile.
With panel goods you can put it together any old way, but you have all the edges to band, which is not a look I really want.
If I was making this piece for myself, I would start with the idea of it, and a blank sheet of paper, and do something similar that used real joinery. But I gather she is already sold...
