Well, no shop time because it is so blasted hot. Last I checked, it was 109 degrees F in the shop and that's with the doors open. Now I remember why I used to close my shop to all project by mid-June and not open it back up until mid-to-late September. Start oncall duty this morning and I don't look forward to that. The LOML and I sat and watched a couple of movies this weekend to take some time to rest. The LOML has one more class in her Master Gardener certification and that will be on the coming Saturday. She is really liking the class and learning a lot.
Heat advisories most all week this week with high humidity, should be a "fun" week.
That's it for me, so what did YOU do this past weekend?
Installed hinges and made a bunch of small knobs. I need to make a bunch of them so I end up with two I like. The rest are thrown to the burn pile and considered practice...
I disassembled and cleaned all of the parts of a Stanley no. 45 yesterday afternoon. I used WD-40 to remove grime and followed that up with a derusting chemical to remove some small hints of rust that remained after the cleaning. After getting everything clean and dry I sprayed stuff down with a light coat of Boeshield which is now dry.
Tonight I get to see if I can recall where all the pieces go.
ATV / 4-wheeler onto a 4' wide aluminum boat, carefully paddled it across the creek to get over to the new lease for a workday. It was so tippy, that both my nephew and cousin declared that neither would dare risk moving theirs over like that, that we needed to look for a better ferry boat. And I agreed.
So after a short search, a friend offered me a free deck-boat, which is just a wide ski boat, that wants to be a party barge. It had been sitting out in a field since 96, where the owner had towed it with his tractor, running over a stump on the way, tearing the axel out from the trailer. All the deck and everything except the fiberglass hull was rotten, making it fairly easy to demolish everything I wanted to tear off, to open it up.
The hard part, was getting it onto my car-hauler trailer, out in midday full Sun heat, after cutting away a thicket, so I could get my trailer lined up. After getting it onto my trailer, the former owner showed up to help for about 1 minute while I was getting blocks of foam under it. He then managed to lever a 2x6" hole through the bottom. Arrrr
Not such a big deal actually. I've already got everything on hand to fix that, and would be mixing epoxy and glass for other modifications anyway. All of the floatation foam in the bottom feels saturated with water, so I'm tearing it all out to lighten it's deadweight, and replacing it with some Polecrete foam that the utility company left down in my sister's back yard after they replaced a couple of poles broken out by the last ice storm. After seeing how easily the bottom could be penetrated in the broad flat bottom, I had concern for it's destiny when it eventually would meet up with some of the many cypress knees down there.
So I googled the properties on this foam, and now am not too concerned about that. This stuff is really tough, and won't soak up water. I'm planning to cut 1/2" treated plywood to fit closely between frames, then mix and trowel onto both parts, then quickly place them together, and let it rise. It expands 15 times in volume, which will probably be about 1" foam between 1/4" fiberglass hull, and 1/2" plywood, for 1.75" bottom thickness.
Next weekend, I should be able to recover the trailer and rebuild it for a couple of Franklins.
When I get it finished, we'll be able to carry 2 ATV's across at once, and drop a couple of ramps off the transom then take off pretty safely, I hope. Due to the nature of this craft and the way we will use it, I think I'll name it D-Day. ha
When I disassemble something like that I use egg cartons and put each piece I take off in one of the cups, so I know what order each piece should go back on.
LOML got her Master Gardener's Certification when she retired about 10 years ago. It's a wonderful hobby for her - and me too. Our yard is attractive (at least I think it is) and she keeps our plants to a very high standard. She loves it. We get up in the morning, have coffee and breakfast, then she goes out to work in the yard and I go to my shop in the basement. We may, or may not, see each other at lunchtime. In the evening we sit down together for dinner and talk about what we did all day. It's a pleasant routine.
BTW, on days like we've had recently with temps >100* for days on end, I really appreciate having a basement shop. It stays cool no matter how hot it is outside. I keep telling my wife that she needs to take up woodworking in the heat of the Summer.
You might also consider outriggers. The steering might be more difficult, but the lateral stability improved. A single ATV weight is at the upper end if 700 lbs. and two placed side by side will not necessarily weigh the same. While you're doing epoxy and foam work anyway a couple of pontoon outriggers may ease anxiety.
And the ATVs will be lower, not up high up on the seats. They will be end to end instead of side to side.
This boat has a waterline 15' long by 6' wide, or 90 square feet. Using 700# x 2 SUVs plus another 400 for 2 people = 1800#. Using 62.5# for a cubic foot of fresh water, this equals 29 cubic feet of displacement. Divide that into the 90 above means it will sit 4" lower in the water than empty.
That shouldn't be a problem since we'll be using ramps to get over the transom anyway, and these rigs can run through fairly deep water without problems.
