Which would you choose? *LINK*
Keith Newton
I'm currently working on building the cabinets for a new house, under construction, for which the owner and builder have ask me to design the kitchen island. I of course tended to lean toward my own style, which I call my Arborescent series, mostly tables, which have the legs grouped together somewhat like a tree trunk.
Sometimes, when I'm dealing with clients, that I suspect have a hard time visualizing in 3D as they are looking at plans, I like to make a maquette. They can then hold it in their hands, and rotate it viewing from all angles, seeing how the light and shadows plays off the details.
The first one was what I first conceived, but then while make it, the other idea crept in, so I went ahead and knocked it out.
I'm not sure of the wood species yet. It may need to be light, I think all the wall cabinets will be painted white, so it will get to stand out.
There are lots of arches around the house, so I wanted to bow the front out, in keeping with that, but also, when people are cozying up to the pleasure side visiting with the cook, they would all have a view of each other, better than all lined up in a row.
Both of these were made by sawing the core out of a 4" thick poplar beam, then cutting the other parts out of mdf, which is hot-glued on. I started out by cutting the pattern for the top, then tried getting everything to fit under that, but I found in the end, the I want a little more overhang, so I probably will back things in a little, or just make the top larger.
The top will be ~ 12' long marble. I think the standard thickness for that is 1 3/8" and the tops here are made from 1/4" mdf, which would be 3" to scale, so that is about twice as thick as the real top will be. However, I will likely have another layer of plywood between the stone and base, which will add another layer of detail underneath, stepping out all around the architectural details, and I'm hoping will keep the upper part visible longer as you get closer.
Here is a link to some pics. I'd like to hear your thoughts.
https://www.flickr.com/photos/7391658@N03/sets/72157655710651965/
