I need a saw sled for cutting miters
Will someone post a picture of one they like?
A KISS version for 45s......
roger lance
We spoke of this before.....can be enhanced by adding toggle hold down clamps and/or strip of sand paper.....
If one side is over 45°......the other will be equally under 45°......giving 90° corner.
Re: A KISS version for 45s......
George Koch
If one cut is over 45 and one is under, the lengths of the cuts would be different. No?
roger lance
Yes
My dad, who was a home builder, use to say that if he ever had a client who was so petty as to get down on his knees and bend over to find some little, almost imperceptible flaw in his work.....he'd kick that client square in his ass.
Hadn't thought of that in years......and on Father's Day too.
Mark Nowicki
Every time I get a customer like that, to stop myself from doing what your father wanted to do, I think of this:
https://www.youtube.com/watch?v=y8EXTzNMOzg
(the good part starts at around the one minute mark)
Thank you, Roger, for a morning smile.
Mark
Mark Nowicki
Similar, but not as elegant as your, for my RAS.
Mark
roger lance
My dad, who was a perfectionist of the old school, never actually kicked anyone (that I'm aware of).....but, would make that statement if he found me or my brother overly obsessing about some small detail because sometimes it's ok to be 99.99% on instead of 100.00%.
That is the case with this jig. In theory, you ought to be able to attach the triangular piece to the base perfectly thus producing 45.00° miters......but in practice, most people making such a jig will not be able to be this precise.
That's why I pointed out that the jig will compensate for this error when both cuts are made and the difference in cut lengths can be adjusted with a little hand tool attention.
Bill, If you are talking ALL angles, 360º
Keith Newton
All you need to do, if you already have a sled, is to cut a 1x2 or whatever you choose for the fence. Drill and put a pin close to one end and front edge, which will drop into a matching hole just off to either side of the blade slot.
From the center of your pen hole, strike and arc 14 5/16" with the finest line you can mark. On the other end, I've just used a drywall screw with the tip sharpened on the tip which sticks down into the sled about 1/8" to hold wherever you press it down, somewhat like a thumbtack. If you use it a lot, and that pin starts to wear out the standard locations, just move it out or in a little for fresh clean surface.
Use a framing square and any other drawing instruments to mark the common settings like 90º 45º 30º 60º, then in between, step off 1/4" marks which equal 1º @ that 14 5/16"
The beautiful thing about this, is that if you are cutting something like an octagon, then find after you have made some test cuts that you were off by a quarter of one degree, which would be impossible to adjust on the standard miter gauge of most TSs, all you do, is lift the swing end, and press it back in 1/16" over.
The larger the arc, the higher the degree of accuracy. So a 28 5/8" arc would use 1/2" marks for one degree.
this works best on larger sleds, so the pen hole can be at least 6" forward of the back fence, so cutting longer parts are allowed to run past on the waste side, without bumping into the other side of the opposite side.
I used to think about trying to making a prototype with the degrees printed on a panel of plastic laminate that could be glued onto any sled, and sold through the regular sources, but I'm not a Salesman, or at least, didn't want to have to get out and hustle to sell something that is just simple geometry that anybody could knock off with little effort.
Re: Bill, If you are talking ALL angles, 360º
mdclor
Keith, a picture would be really helpful. Thanks.
Re: I need a saw sled for cutting miters
TomD
Those are some nice tools so far. But if I am not mistaken, these are the only ones that actually work:
http://www.bridgecitytools.com/default/tools/table-saw-fences/table-saw-sled-kits.html
This is the one I use *LINK*
David Yoho
Bill, I'm guessing you're wanting one that is shop made but I've been using one I bought many, many years ago. In fact, I have two. One for each side of the blade. They have seen so much use in my shop since purchase they have earned their keep and then some.
Dubby cutoff sled
