Spice Box base molding
Kind of a lame post but it is a move back to woodworking. No Saw Stops were harmed in the preparation of this molding. :)
In spite of getting ready for SAPFM meeting and Mr. Duffield's visit and the chance to hire a neighbor for a few days to catch up on farm work, I got the base molding installed to my satisfaction. As mentioned previously, a two piece molding looked better to my eye than the result of milling the profile from one piece.
In a later post I would like to discuss your techniques for wrapping mitered molding around a case.
In a recent Pop. Woodworking G. Walker discussed the Cyma curve and showed how to lay it out from segments of circles. This approach for the Cyma on this base molding looked too formal to me. The upper arc I used is not a segment of a circle. It is more like an ellipse. I liked to look better.
Re: Spice Box base molding
PS = the shelf liner
Note the box is sitting on shelf liner, I keep pieces on hand to go between bench and projects near their final finish. I find it works to keep scuffs and scratches off the product. Junk falls through the holes where it is largely harmless toward scuffing the project.
Base molding.......
roger lance
I'm showing a base molding that "suffers" from the two things you listed.....the curve was largely arrived at mechanically with circles.....and the molding was cut into the one piece molding with less detail than yours.....
I like yours more. That room is being remodeled.
I often grab my french curves...
Grant in Iowa
When faced with laying out such things, I will often go for my french curve set(s). I think I have two sets of Alvin brand french curves and some Steadler ones that provide curves that seem more or less based on the parabola. The different curves are generally defined by geometry, and tend to have a linear progression from one end to another. I don't know all of the ins and outs, just that they are very useful for making transitional curved lines that are pleasing to the eye and fit a given space.
Some french curves, especially those used in clothing making, have graduated marks. I figured out that these marks allow the user to smoothly transition a curve from expanding to diminishing when using pieces from the same set. I think the numbers relate to the degree of change at that point along the curve. So if you want to use a section of the curve to draw a portion of a curved line, then want to transition to --say a spiral or change of any sort really, you might stop one curve at the "5" mark, and pick up another one (or flip the current curve over), and continue from the "5" mark for a near seemless transition. I don't claim to know the "official way" to make smooth transitions with these things, but I am convinced the numbers have something to do with it.
So I might use several areas of the assorted curves to achieve the finished result, which I will cut out of thin material for a template that can then be flipped left and right in order to create mirror images of the same curve. This is transferred to the work piece for final cutting.
Sadly, I can find no images of stuff I have made with them at present. I can only say they are handy as heck to have around the shop. Not very costly at all, either.
Regards,
Grant in Iowa
I find this image online that shows what I am talking about:
Re: I often grab my french curves...
TomD
I have some ships curves, full sets are silly expensive, and I have larger (and very reasonably priced) pattern drafting curves, and basically anything I can pick up. It would be great if these curves were available in CAD, but I guess that misses the point. I do design curves in CAD at times, or I will plot a particular curve using circles or ellipses in CAD. But there are problems with that as well as benefits. It comes down in the end to what looks good to the eye, and it is hard to get a good view in CAD at times.
I think you can run the various curves together at any axis of tangency. I either mark them with a felt tip, or where they have numbers I can choose a related number.
