Does anyone know the secret to removing sliding glass doors? I tried lifting them to tilt them out but there isn't enough clearance to lift them high enough. Also, I didn't see any retaining screws or anything else holding them. Thanks!
On the sliding doors I use to work on there were screws on the bottom rail, usually on the inside. Take the plugs out, if there are any, then there are screws down in the hole, if you screw them one way you raise the door if you turn it the other way it`ll bring the door down. Bring the door down as far as you can, then try and lift the door.Sometimes the door needs to be bumped around a little but it`ll come out. Good luck.Larry
Larry is right. You workign on a vinyl door or an aluminum one? On the aluminum ones the adjusting screws are on the edges. Also, the doors have to be lifted and then the bottom comes out to the outside. The inner track is taller. Be careful, they are heavy. Some of them barely come out, but they do.
