Spice Box Jewely Box- Agony of the feet
A problematic decision was made in the beginning of this construction. For a reason I no longer remember I chose to assemble the case with through dovetails instead of half blinds. This decision has led to complications installing the base feet. The puny area of the dovetails is marginally small for attaching the base/feet, and, whatever is done down there needs to cover up the dovetails.
A complicated solution, as it became, is to use an approach used in period Boston furniture and install a mortise and tenon support piece on the bottom of the box as show in the picture(box is upside down in picture, bottom on top). It is glued along the front but nailed along the sides to accommodate changes in the depth of the case with season. This addition provides more surface to attach the base and feet.
A comment here about the bar clamps. I do not share the enthusiasm for the Bessy clamps many use. I find them heavy and awkward with no compensating advantage over the clamps shown in the picture. Not only are these clamps, now available from Lee Valley, useful for panel assembly, but their light weight and small profile makes them idea for case assembly, as illustrated. Our club bought hundreds of these clamps from the manufacturer for delighted club members.
In a subsequent post I will describe the agony of coming up with the Cyma curve for the feet, and the procedure for installing the base/feet.
Re: Spice Box Jewely Box- Agony of the feet
roger lance
I've used a similar technique often....especially on very heavy items like my Shaker style workbench or large bedroom dressers.....where that added bottom structure is actually supporting the piece by extending it just slightly past the ornamental base trim.
Another structural technique learned at the school of Norm Abram.
Bar Clamps
Dave Bair
I have both types; weight is the only advantage I find with the hollow clamps. Their jaws have a much smaller clamping surface and cannot be counted on to remain parallel, under even moderate pressure. The Besseys are easier to adjust since the heads can grip anywhere along the clamp's length rather than the every-2-inches stops on the hollow clamps.
Re: Bar Clamps
roger lance
Dave......thank you for such a fair & balanced, unsolicited, insightful, unprejudiced, comprehensive, complete and thorough review.
I also own Besseys.....just sayin.
Re: Bar Clamps
William Duffield
I like the Bessey's because you can stand them on end, either empty or with an assembly clamped up. Note in Bill's picture that the assembly is clamped to the bench top, and all the clamps are on one side, hanging over the side of the bench. If you want to clear the bench for another operation, it's difficult to find a place to set the clamped up assembly.
not so
It was so light with even the 4 clamps that I could have just set it aside anywhere......but there was irrigation to attend to. Driest May ever and record hot too. No rain here in 4+ weeks.
William Duffield
Cases were very commonly joined with through dovetails. There are at least three strategies commonly employed to hide them with mouldings, when using bracket feet.
The worst way is to join the foot to the bottom of the case with glue blocks and glue and nail the moulding to the tops of the feet and the side of the case.
Another strategy is to use wide stock for the mouldings, and cut a rabbet in the inside top corner of the moulding and drop the case into it. Attach the feet to the bottom of the moulding pieces.
A third strategy is to make the feet themselves from wide stock, so that both the case and the moulding are set on top of the feet.
Lee Valley clamps have feet too
And given that 4- LV clamps weigh less than one Bessy it is easy to just turn the piece on its side or move it elsewhere or even hang it from a hook.
The near weightlessness of the clamps LV sells is a substantial advantage in project glue-ups. Yet they are strong enough for Industrial panel gluing (testimony from their inventor who sold them for this application).
Kneale Brownson
I like Bill's final suggestion.
