Spice Box update- board flattening
Choosing the tops for the spice boxes related to some recent discussions of flattening lumber and lumber waste.
Unless the piece is structurally unsound I don't throw anything away. The tops for the spice boxes will be made from two cut-offs from boards used to make something from the past, I can't remember what. But the grain was interesting and I thought I would/could use these cut-offs sometime, for something. The size is adequate for the spice box tops to be cut from these pieces.
Given this wild grain these pieces were not flat to begin with. Nor did they need to be and I spent no time considering their unflatness. The tops will be 5/8" thick and in this thickness they will be flexible enough to easily squash flat on the stiff box framing. I did spend some time being sure of the grain orientation before running them through the planer.
This aspect of the Spice Box project illustrates that almost any scrap of lumber may become useful in some later application. Additionally, it illustrates that how flat a finished part needs to be depends on the application of the part. I did a lot of fretting on the slender door frame parts that had to be perfect to get a good fit of the door to the case ( more on this aspect at a later date)
PS While you may not notice it, compared to my old Cannon A series I am delighted with the picture quality my new G15 Cannon is taking.
Re: Spice Box update- board flattening
Philip Duffy
Such great stuff its too bad there is not enough thickness for a gunstock to two! P.
Beautiful stuff. Are you keeping the knot or cutting it off?
I wondered that also.
Joe in a Cleveland suburb
I was wondering how the spice boxes were coming along.
Thanks for the update.
roger lance
That is a good picture.....lots of grain detail.....isn't technology wonderful !!??
Hank Knight
That's beautiful walnut, Bill. I agree that most scrap is useful, so I find it difficult- almost impossible - to throw scraps and cutoffs away. They have taken over my shop. Occasionally, I nerve it up and thin out my many cutoff bins qnd boxes. Even then I just can't bear to chuck anything in the trash. There's got to be some mindset that would help me separate the keeper stuff from the throw-away. Your walnut shorts are definitely keepers. They will make beautiful tops for your spice boxes.
Thanks, Bill, and a planer question
Grant in Iowa
Bill,
It occurs to me, given your experience, you may have knowledge about planer knife back bevels.
I recall reading about how planer knives are typically ground from the factory to perform best on soft woods. And I read further about how some have had good results grinding a slight back bevel on the face of the planer knives for better performance in hardwoods and figured woods.
I did ask my sharpening service about this at one time, but he plead ignorance, and suggested the stock profile was as good as it gets.
To be sure, such a grind would cause a greater load on the planer motor, and likely necessitate a lighter feed rate. Given that, I am still intrigued at the possibility of planing a figured part with less tear out.
Thoughts?
How my knives are ground
I have a grinder attachment for the Powermatic planer. It grinds a primary bevel and then a secondary bevel at a somewhat steeper angle. I get the best results when the knives are sharp and the feed rate is slow. If the board is narrow I may try to skew it.
Re: Cut off reuse
I have accumulated (horded) many small pieces of cut offs. I will save any like Bill has pictured, but did have a LOT of Cherry, Hackberry, White Oak, Hickory, and other hardwoods with no exceptional figure. A couple of years ago or so, I decided to smoke some meat, I had ran out of purchased chips, so decided to use some scrap. I cut about a bushel basket of small pieces, put them in a bucket of water and weighted them down with a brick. Worked great, and I have made some for friends and family. I have kept the bucket full for weeks and it is ready when needed! I like the fruit woods for chicken and even beef, Hickory and oak is much stronger but works well for pork. Guess you will decide what you like after a little experimentation, as everyone's taste is different.
I have tried several woods that you would not think would work well but did. Still have more cutoffs than I will ever use but sure did lighten the shelves. Also use tree trimmings off my Apple, Peach and Cherry trees. Works well green, but do need to remove most of the bark or it will give a bitter taste.
why  knot ??
del schisler
tight knot's look's good in some building of box's , my self i like them and wild grain , nice looking boad's
Re: Alternative Uses for Those Boards
William Duffield
Those boards have some really exceptional figure. I can't tell their dimensions from your photos, but there are several design options I would consider before making a final decision to use them for spice box tops.
Depending on where the spice boxes will be located, the tops may be above eye height, and therefore not be very visible. If high enough, through dovetails are often used to join the tops to the sides. I seem to remember that you are using half blind DTs, so only the joinery in the case sides need to be covered by mouldings.
I would explore the possibility of resawing the most highly figured parts of those boards (and tossing the knots in the firewood bin :) ) and applying the resulting thick veneer to the drawer fronts.
I have some nice drawers
Rift and Curly
