GE Overload Heaters
GE Overload Heaters
GE Overload Heaters
Henry Higginbotham
I'm helping someone convert a 3-phase Delta sander to single-phase. The single-phase motor will require changing the heaters in the GE starter.
Anyone here know if the GE heaters are a one-shot deal or if they somehow reset themselves? I'm only familiar with the Square D heaters with the little ratchet mechanism turning in the solder pot. It isn't obvious to me how the GEs would reset. Noodling around on the Internet hasn't gotten me an answer, and the electrical forums don't seem to welcome non-electricians.
They look like this:
Re: GE Overload Heaters
TomD
Can't help you, but if nobody here knows the answer, I have found this place helpful
https://forum.canadianwoodworking.com/forumdisplay.php?23-Shop-Electrical
Dick Coers
Just guessing, but looks like a one shot deal to me.
Larry in NW Ohio
If you would have a picture of the starter or the switch from where the heater comes from I may be able to tell. How old is this unit? Larry
Henry Higginbotham
The sander is probably 10-15 years old. It's about 60 miles away, so I can't provide made-to-order pictures, but here are a couple I made a while back showing the overload relay (GE CR324C310A4). The plunger thingie on the left looks like it could be a reset, and there is an adjustment, 90-110, that might be a delay or sensitivity setting (reaching, here).
What little I've found on the unit seems to indicate that it's resettable, but it's just not clear to me how these heaters could pull that off.
None of this is critical--short of a locked rotor condition for some reason, I don't see this sander working hard enough to affect the heaters, anyway. I'm just curious as to how a reset would work (if it works).
Keith Newton
Henry, Rather than those heaters actually breaking the circuit, I'm wondering if they just get hot, causing the sensor on the left to actually break the circuit that runs through the start/stop button through the coil, then through this overload protection.
I can only see one wire coming off the bottom, but it looks like there may be a connector missing a wire toward the back. If you have the wiring diagram, and a tester, you may be able to trace the problem. I don't have anything with this switch on it, so sorry if I'm wrong.
I hope you have tried pushing this button. Also, since you are dropping down to single phase, make sure that the wire out of this overload switch on the left, doesn't end up going back to the unused third leg.
Henry Higginbotham
Hmmm, that sounds plausible.
There isn't any problem, as such. Everything is hooked up and operating and the magic smoke is still contained. The dangling wires (and all the loose ones you can't see) are as we received it--and since fixed. Like I said, just a curiosity. I may never encounter another GE starter, but I like to know how things work, especially if they look like they wouldn't work. The notion of heat triggering another component is something I hadn't thought of.
Larry in NW Ohio
OK Henry I`m going to try and get into my way back machine and try to remember how this worked. The button on the left is your heater, circuit breaker if you want to call it that, when something happens with the motor, a stall or whatever, the heater, which is the thing you had in the first picture with the curl of wire with two hole to mount it. That heats up when the motor stalls or whatever, then the heat makes a circuit breaker like thing to snap open to cut off the power going to the motor and shuts it down to keep it from burning up, and the button on the side is to reset it, Henry. Know that everone is clear on that. If I had it here I could probably fix it. Any more questions I`ll try to explain them.Larry
