Turn signal indicator
Larry in NW Ohio
My turn single indicator in my 2012 Traverse works very funny. I turn it on and it`ll blink a couple of times correctly and then it`ll start to blink fast. Does that mean that the bulb is burnt out, if so how hard is it to replace. Thank You Larry
Re: Turn signal indicator
John McGaw
Well, if a bulb is burned out then looking at the vehicle, front and rear, while the signal is on will tell you. Actually it is de rigueur that one do this check along with the brake lights, running lights and headlights on a regular basis but...
As for changing the bulb it can be easy, it can be hard, it can be futile. A look at the owner's manual should show the necessary steps. This is assuming, of course, that a bulb that is not flashing is the fault of the bulb. More than once I've had wiring or socket problems causing such troubles.
Mark Nowicki
The rear ones are easy, the front ones can be a pain.
Mark
Some "full" service auto parts stores will install some of them for you or at least talk you through it.
Ray Thompson
May be an intermittent connection. When it starts the rapid pulse try to stop and see if the front or rear is not working. Later take it out, clean the contacts and see if it works better.
Ray
Stuart Johnson
When my bulb burn out the indicator started to blink very fast. It was a 1976 Fiat Spider so yours might be different.
Larry in NW Ohio
Thanks everyone, I was able to look at it closer and I can see the bulb is burnt out. It`s of course the turn signal bulb and it looks to have only one fillament in the bulb and the glass is black, good indicator I`d say.. The only thing I can see to get it out is two screws, but I`ll find that out when I get to it. Larry
Tom Dunlap
"The only thing I can see to get it out is two screws, but I`ll find that out when I get to it. Larry "
I chuckle...that's what I thought one time when I had to work on headlights. The two visible ones were just the beginning! It was a serious lead-to project to get the headlight out!
YOu might try a google search first...just to be forewarned.
Tom
Joseph Mulherin, sr
Larry, try using YouTube to see if there is a video showing and explaining about the light change outs.
Re: Turn signal indicator - *Link*
Bob Entwisle in NJ
Hi Larry,
Here's a couple of links that describe replacing the bulb on a Traverse, one for the front bulb and one for the rear. When you get into the links they call out 2009 - 2012 model years for the procedure.
Front:
http://www.carcarekiosk.com/video/2009_Chevrolet_Traverse_LT_3.6L_V6/lights/turn_signal_front
Rear:
http://www.carcarekiosk.com/video/2009_Chevrolet_Traverse_LT_3.6L_V6/lights/turn_signal_rear
Hope this helps.
Bob in NJ
Larry in NW Ohio
Again Thanks everyone. While some of you were posting, I just happened to take the car up to O`Rielleys auto parts and the "Kid" that was there was really nice and seemed to know something about it. So between him and myself found the TWO and ONLY TWO screws and the unit just about about fell out also the bulb just sort of twisted out and pulled out the bulb, pushed ONE of the TWO in the package and put it back together and wahlaa, I think that is how you spell wahlaa it worked. Again thanks, and thanks to Ellis for starting this site, I`ve saved a bunch of money by coming here to fix things. THANKS ELLIS, by the way did you get my donation from Pal Pal. Larry
