I have a Sears model 113-299XXX table saw I bought used several years ago. It has served me well until starting became erratic a few weeks ago. I would turn in on (made sure it was plugged in) and once in a while not start unless I turned the switch on and off a few times. Today it would not start at all. I don't know if the switch is bad, the capacitor is bad or the motor and don't know how to check. Any advice would be most welcome.
Jim The most likely problem is dust in you switch. Just UNPLUG the saw and take the cover off and take compressed air and blow the switch out as best you can. Also you might tap the switch with a stick and blow it some more. If your good at fixing things, take the switch apart, as a last resort. The contacts may be carboned up. Good luck. Larry
I didn't look to see what kind of switch it has, but that is very likely. However, you need a tester to easily track these problems down. If you can get at the wires going in and out of the switch, you can easily test to see if the current going in is coming out the back side.
Then go to the other end of the wire out to the motor, and test it there.
I have a sears contractor saw, not sure of the model number. I had the problem you described, a few years back. Had to clean dust & debris out of the start capacitor. Now I have an air compressor and blow out the vent holes on the side of the motor every couple of weeks. The problem has not recurred. Good luck
Quite a few years ago I had the same problem. I took the motor into a local shop. All that was wrong with it was it was full of dust. All they did was blow it out. Now I try and remember to do that once a year and it has not been a problem.
Jim, I kind of hate to give advice not knowing how familiar and knowledgeable you are about electricity, due to safety concerns. However the first thing to do to troubleshoot a problem like this is to "divide and conquer". IE: To determine where the problem exists, you need to know if the motor is being fed power. First UNPLUG the saw. Then remove the motor electrical cover and using a VOM (Volt Ohm Meter) attach the leads of the VOM to the motor leads (Black / White) or Red / white). Unless you are pretty familiar with electrical testing, tape the attached leads to insulate them so you won't be shocked. Then set the VOM to the proper voltage measurement scale (if a 120 volt saw set to the lowest AC voltage scale ABOVE 120V, if a 220V saw do the same except the scale above 220V AC.) Then plug the saw in and press the start switch. If you read the proper voltage on the VOM the problem is in the motor, if no voltage is read your problem is with the start switch (provided your electrical cord is not damaged).
Now unplug the saw then:
If the problem is with the switch, as has been recommended try blowing it out. If the contacts are visible and accessible clean the faces with a nail file or strip of sandpaper, then blow out and clean off all residue from the cleaning process. Reassemble the switch, and plug in the saw and see if your problem is solved.
If the problem is with your motor there are two very common problems, 1) Dust can get in the motor start switch contacts preventing the motor from starting, or Debris can build up on the motor shaft preventing the start switch from closing. Sometimes blowing out the motor with air can cure both problems, other times the start switch has had the contacts burned and requires replacement (best handled by a motor shop).
Or 2) Many motors have a Start capacitor, If this fails the motor may not have the power to start. This requires the replacement of the capacitor, most are soldered to the leads so if you are not familiar with this process, best remove the motor and take it to a motor shop.
I have the same 113 model saw. In case you don't know you also should lubricate the motor bears at least once per year. There are plastic plugs on the bearings at each end of the motor. You need to pull these out and put in several drops of oil in each one then put the caps back in.
Thank all of you for the advice. Blowing dust out of the switch housing, capacitor and motor did not solve the problem. I have been trying to find a circuit tester that is battery operated, has a lightbulb and will let me know which of the components is not working. The capacitor has two wires with push on terminals so I should be able to replace it myself if that is the problem.
Even with the power off, you can get a big jolt out of a capacitor.
If you are after the simplest tester, you can find one about the size of a felt-tip marker that will light up and beep when you get it close <6" to a hot wire. You can start at the outlet, then follow the cord to the switch, and on out to the motor, if the switch is on, and the problem is back at the motor.
is that the problem can be on the neutral side, so it may only be half right.
You could have a loose connection on the neutral side of the plug, on the end of the cord, which would provide a hot wire all the way into the motor, but the problem could be back over where it plugs into the wall. Or in a 220V circuit, one good and one bad will give a false reading.
Getting a meter that shows volts, gives you better feedback. If you start at the receptacle with xxx volts, but find a big drop behind the switch, or anywhere along the way, you can zero in on where the problem is.
I had one of those saws years and years ago. I had to wire it up so that the cap was on a momentary switch and the motor was on a regular one. Previous owner had done some weird stuff to it as I recall.
It sounds to me like you either have a bad cap or the centrifugal switch that drops the cap out after startup is bad. Hard to tell which any other way than playing parts bingo. Usually it's the capacitor, but not always as my old saw demonstrated.
Many digital multimeters come with a cap meter setting these days. Mine cost about $20 from Radio Shack. That option may be disappearing, but I'm sure there is an appropriate meter available on Amazon. I buy new motor capacitors from McMaster Carr, though you can get them plenty of other places too.
We're so used to thinking sealed ball bearings are best, but really they are just low maintenance. I had a faceting machine with a motor like you describe and had to take it apart and clean/oil the bearings once - bronze bearings with a felt oil reservoir. Probably could have just oiled it for the same result, but I didn't know that then.
Anyway, it went from hot and noisy to nice and quiet with just some oil. Good as new.
