Porter Cable edge guide
Jerry Gibbs
Does an edge guide for the PC router 8901 exist? any info appreciated.
Jerry Gibbs
All 890 series router uses the same *LINK*
Dick Coers
Pretty sure this one works, but I don't have one to verify.
http://www.deltaportercable.com/Products/ProductDetail.aspx?ProductID=16399
Re: Porter Cable edge guide
Jesse Cloud
I'm not familiar with the 8901, but if this isn't a tool you would use often, its easy to throw together a makeshift edge guide. Just attach a piece of 1/4 inch ply or other material to the base and attach a piece of wood at the relevant location.
Its not adjustable, but its cheap and you can make one in a few minutes.
Re: All 890 series router uses the same
Walt
I'm pretty sure hole patterns - base and edge guide between the 690 and 890 are the same. Big PC routers are different.
8901 is just the fixed base number *LINK*
Dick Coers
An 892 router is an 8902 router motor with an 8901 fixed base.
Porter Cable
roger lance
Number 8901 is the fixed base unit for the 2-1/4 hp router motors which has three router models (891, 892, & 893).
Router edge guide #42690 is for use with router models 100, 690, 691, 693, 891, 892, and 893.
So, yes, an edge guide is readily available.
