Ship Display Cabinet
Gary Smyth
Does any one happen to have a profile of rails and stiles for a traditional thin pillar wood and glass ship display cabinet similar to below? There are dados to capture the glass but I'm not sure how the (glass) top and bottom are fitted and fastened. A three way miter is not an option. Neighbor said that the hardwood and glass "box" commercially priced for his model size was quoted at $400 for a size of 22 L x 10 W x 24 H. He has months to go to complete the model, but it collects all kinds of foost in the space of time he gets to work on it. He thought it best that the model be covered (and the cover able to be removed) while being completed-- but not for four hundred bucks. He didn't ask but I thought I'd ask around as the problem seems interesting.
Re: Ship Display Cabinet
Tenons
I repaired an antique doll cabinet similar to these. The legs were tenoned into the mitered corners of the top and bottom. You can make the top removable by attaching it with screws down into the tenons. The legs are actually grooved, not rabbeted, for the glass.
$400 isn't that bad
Dick Coers
Glass will be close to $75-$100, so that only leaves $300 for the woodworking. I would use a dowel, or Domino loose tenon to join the corners to the posts.
Keith Newton
I think you should bond the glass like aquariums, which will be stronger than the tiny joints you will be left with. Then the wood can be L shaped corner trim, bonded to the glass box.
SAR Plex might be the best choice, if he wants to lift off the whole glass box while in progress, rather than lifting the top off, and taking the model out.
Re: $400 isn't that bad
John McGaw
I'm pretty sure that there wouldn't be enough room in those joints for the domino joint since it would require three at each corner. Frankly building something like that is plain scary: if it is to be durable, what sort of joinery to use?; if it is to be repairable how to retain the glass?; what glass to use for safety, or would scratchable plastic work?
As someone else suggested, I figure that aquarium-style construction would be best with the edges merely concealed with thin wood. Given the expense of custom tempered glass for safety I'd go with plastic. Of course then you get into the acrylic vs. polycarbonate question.
William Duffield
I built a similar boat display cabinet several years ago. I don't remember all the details, but it was quite a bit larger than yours, maybe 40" tall and 48" wide. The frame was assembled like the frame of a table: tenons in the ends of the rails, mortises in the stiles. The stiles were about twice as thick as the rails. The lid and base were separate assemblies. The frame set inside the moldings on the bottom, and the lid dropped over the top of the frame, with the moldings again capturing the frame. I held the plexiglas panes in place with grooves in the stiles. The panes slid in from the top, after the frame was sitting on the base, after the finish was applied.
Here is a cross section of a stile and two rails. It is applicable to both the upper rails and the lower rails, but is not to scale.
We set the base on the floor, set the model on the base, dropped the frame over the top of the model, slid the four panels into their grooves from the open top of the frame, set the assembly up on the shelf in an open stair well, and finally set the lid up on top of the frame. I built the shelf, too.
William Duffield
There's plenty of room for dominos, and it only requires two at each corner.
Very nice !
Re: Very nice !
William Duffield
Sorry I don't have a better photo of the case. I do have a detail photo of the shelf.
The bullseye glass was captured in a sandwich between two thinner boards, with rabbets to fit the glass, which were then glued together and shaped. I wish I remembered how I attached the shelf to the wall, but I don't. I should have used short French cleats, hidden behind the trim piece, but I don't think I did that. I think I screwed it to the wall and then installed the trim piece and screwed it in place from the top of the shelf, which is above eye level.
Gary Smyth
Thanks to all. Special to Keith (aquarium idea) and William for the diagram. Took info to model builder. He reported what he located.
If anyone has interest--found on overstock,com
Several sizes available. Prices from $290 to over $600, depending on size. Presumably the bow in the wood is a photo aberration. AD copy copied for relaying info only, no other link to me.
Old Modern Handicrafts Display Case For Tall Model Ship
Overall Rating Rating 1 | 1 reviews | Write a review
Today $346.99
Save $87.46 (20%)
At other retailer: $434.45
Item #: 15139727
High Sellout Risk
This beautiful display case was made out of hard wood and painted in dark mahogany color. This case is 100-percent fully assembled and comes with plexiglass panels on all sides.
◾Color options: Painted
◾Materials: Wood, Plexiglass
◾Inside dimensions: 32.5 inches length x 12 inches width x 29 inches high
◾Overall dimensions: 34 inches length x 13 inches width x 31.5 inches high
Lee Schierer in McKean, PA
I made a display cabinet similar to what you are trying to build a number of years ago.
The corner post are about 1" square. I cut grooves for the glass which was 1/8" thick. The posts are attached in each corner with screws up through the board holding the medallion. The top is a box with open corners that slide down into the grooves after the glass is inserted and then the very top has a single screw down into the vertical members at each corner.
You could make the upper frame as if it were a picture frame and make the corner posts as I did for the display case. Screws up from the base and screws down through the picture frame.
Lee
