Spaceballs question
Tom
When using Spaceballs how do you size your panel for cabinet door construction?
Spaceballs question
Tom
Re: Spaceballs question
roger lance
Have to make a couple of assumptions:
1.) the spaceballs are 1/4" in diameter
2.) the panel groove is 1/4" wide x 1/2" deep
At this time of year, the panel would be dry and the expectation is that the panel will swell from this point in time. so, I'd dimension the panel width to be just slightly compressing the spaceballs so that it will not rattle in winter and yet has enough room to swell and compress the spaceballs more in humid summer.
In the high humid summer, the panel will be swelled and the expectation is that the panel will shrink in the winter. So, I'd dimension the panel width to strongly compress the spaceballs and be able to contract but still have some compression on the spaceballs in winter.
The panel height would be the same in both seasons with the panel making some compression of the space balls so the panel would be stable in that dimension in the frame as well.
A recommended shop aid.....
roger lance
since I work a lot with QSWO, I keep a glued up panel scrap suspended from my shop ceiling and I've written the measured length of that glue up and recorded the date of measuring on the panel so I have a way of estimating how a panel will behave depending upon when its made......
always use the same measuring tape to eliminate error between tapes.
i like Rogers answer but would like to add,
Keith Newton
You MUST know the beginning MC, moisture content of your wood, and that plain sawn lumber will typically move twice as mush as QS, and some species more than others, and of course if the wood were to be exposed to higher humidity, like for an entry door, the change will be far greater.
Or for a simpler answer, if your wood is just air-dried, make them as tight as you can make, and still assemble.
Dick Coers
Never could see the purpose of buying space balls. I don't mind the rattle, but if I did, I would take the time to find the center of the panel on the center of the rail. Then just a dot of glue on the center line during assembly, and no rattle. Some people bore a tiny hole though the back face of the rail, into the panel. Then tap in a toothpick to plug the hole. No messing with glue then.
Agree
I regard them as a solution attractive to mass assembly operations, unnecessary for woodworkers. Personally I tap a tiny brad into a predrilled hole in the rails.
Re: A recommended shop aid.....
Alex Grigoriev
That's the nice example of why metric makes so much more sense than inches with fractions.
roger lance
This is America......we don't do things here because they make sense.
Re: Agree
Tom
The reason I am using them is this is a kitchen project with quite a few doors. By using them it will speed up the assembly process.
