tiger maple finish
Paul Blackwell
I'm building a jewelry box from some beautiful tiger maple. Does anyone have a good foolproof method of making the grain really pop? I don't have spray capability. Mostly I finish projects with polyurethane.
tiger maple finish
Paul Blackwell
Re: tiger maple finish
Joe in a Cleveland suburb
The more knowledgeable finishing folks here I'm sure will respond, but if you have access to FWW on line or someplace, Jeff Jewitt did this article:
Pop the Curl in Curly Maple
Fine Woodworking #135, pp. 38 April 1 1999
For the wall clock I am making right now I plan to use some diluted reddish brown TransTint dye, sand most off, then some Old Maple dye, then flood it with BLO, then shellac.
(I forget the exact names of the dyes.)
I like the look of it on some scraps I played around with.
I asked Michael Dresdner this question on the guest chat he did here on 1/2014 and I think his response was to just flood with BLO.
http://www.woodcentral.com/chats/dres_transcript140109.html
Good luck.
Joe
John in NM
I like to go for an amber color, since maple gets pretty yellow with oil and age. A dye is the easiest way to go, I've seen nice results with that - take a look at Ellis' gallery page for an example. The color helps pop the grain some in addition to making a more pleasing finish over the long term.
I've not done a lot with dyes, but that is the first place I'd look. After that, oil and some kind of film finish and you're all set.
I've also used the old style colorant, a ferric solution which reacts with the tannins to color the wood. Basically the same sort of color effect as dying the wood, but for some reason I like learning the old way.
Whatever you do practice on a scrap or scraps. Try your finish and put it in the sun for a few days to see how you like it.
roger lance
2nd the Jeff Jewitt/Trans-Tint dye approach.....should be numerous sources of info on this method online.
Lee Schierer in McKean, PA
I like clear lacquer in a semi gloss finish. That is what I did with this box.
Lee
Doesn't that also have the advantage...
John in NM
Of not yellowing over time?
Great looking box Lee
Re: Doesn't that also have the advantage...
Not nearly as much yellowing as polyurethane.
Lee
