infra box joint
Peter
I have made allot of box joints with a one quarter inch blade, i just tried with a 5/8 and can not figure it out. can it be done or am i just missing something.
[please help
infra box joint
Peter
[please help
Re: infra box joint
A few more details woudl help me.
If you are talking about a standard box joint or finger joint, almost any dimension can be made to work. For a 5/8" blade the height of the blade would be the thickness of the material and the off set woudl be 5/8". The Finger you use to sett he spacing woudl also be 5/8".
Are you talking about using an Incra jig?
Dick Coers
And a router bit, or dado head. What's not working?
Re: Are you talking about using an Incra jig?
Peter McLaughlin
Yes I am using a incra box jig. I made beautiful 1/4 in joints with table saw then changed to a bigger cut and it did not work.
Dick Coers
Sorry, no nothing about that jig. I have the Incra fence.
I Box
David Yoho
If you are using the Incra I Box jig you would need to adjust for the larger size fingers. Another look at the DVD or instructions will get you back on track. The inventor of that jig frequents this forum and maybe he will see this and respond. I have one but other than setting it up last year and running some test joints I haven't used it enough yet to give a detailed answer off the top of my head.
mdclor
I finally got mine set up for 1/4" cuts after a lot of fiddling and a call to customer service and this was after watching the video. I haven't dared to try any other settings for fear that I would never get it set accurately to any given dimension ever again. I do seem to recall that there are 3 things that need to be simultaneously and perfectly adjusted to get the desired width of cut. Sorry, I am no help.
Re: infra box joint
roger lance
I've made a number of projects using various sized box joints on the tablesaw with a dado blade set. As I recall, the dado widths are not always spot on meaning that 5/8" may not be exactly 5/8" and as the joining pieces get longer, the discrepancy becomes an issue. How this works with an Incra, I'm not sure.....I've just used a shop built jig.
Re: infra box joint
David Yoho
Roger, on the Incra I-Box jig you actually set it up for the width of the stacked dado set (outer edge of each tooth). A few test cuts is all it takes to dial it in to exactly match the width of cut no matter the size. Depth is another adjustment. Once set up, the I-Box is super accurate. Since I haven't used mine in a while it would take going over the video again to become familiar with the set up adjustments. I do seem to recall once it's set up for a given width box joint you only need to adjust one of the "fingers" because the other one doesn't change unless you use a different stacked dado.
