Ohio Sawmills
Ohio Sawmills
Kneale Brownson
Ohio Sawmills
Kneale Brownson
I have a daughter in Columbus with the woodworking bug whose basement shop would be served best with finished lumber. Are there mills nearby that turn out finished dimension lumber?
Re: Ohio Sawmills
Re: Ohio Sawmills *LINK*
walta
try this link
Walta
Woodfinder
Re: Ohio Sawmills
Kneale Brownson
Re: Ohio Sawmills
Kneale Brownson
Now why didn't I think of that????
Re: Ohio Sawmills
Re: Ohio Sawmills
Larry in NW Ohio
Walta Just in case that woodfinder does not bring them up, there is a sawmill just outside of Delphos, Ohio, called Siefker sawmill. Also Frank Miller in Union City, Ind. Don`t think that is not in Ohio, it`s partly in Ohio and partly in Ind. , also there is Yoder Lumber in Millersburg. Good Luck Larry
Re: Ohio Sawmills
You ask for, Ohio Sawmills, BUT, *LINK*
Keith Newton
It sounds like you meant to find a lumber yard with services. Those may not be the same services.
I think most Sawmills are likely to sell green lumber, which while cheaper, ends up costing in the long run to get the MC on down to a usable level.
http://www.woodweb.com/cgi-bin/directories/sdd.cgi?&PAGE=11
Re: Ohio Sawmills
Re: Ohio Sawmills
don stephan
Dressed lumber is seldom flat and straight. It's close, but not as good as it should be for making furniture in my opinion.
